Another Pro Lifted with 6112s (pics and measurements) UPDATE: Added 285s
You are a brave man...
Do you know how many miles the 6112s and their TRD equivalent normally last? 60-80k?
Lol. Took me a while to get up the nerve.
I don't see reason why they wouldn't, depending on how much abuse they get.
great work. i may try the approache as well. as for alignment, do you mean camber or caster ? looks like your camber is okay and your caster ran out of adjustment room.
what tire size are you planning? is the bmc required?
Thanks. Yes I was referring to the caster. I'll be running 285/70R17s on stock Pro wheels with 1 1/4" spacers. I'll need the BMC mostly because of the spacers.
so your doing the bmc because of the spacers and not because of the tire size and lift :) got me scared because i'm doing a similar setup soon and was not planning on bmc :rofl:
Yeah most people say you can get away with 285s with some trimming, but with the spacers is a must do.
Update:
Made a 800 mile road trip this past week.
Suspension did great on the highway. There really wasn't any negative things I could say about it other then being a little sharper on stuff like expansion joints and just road imperfections. Nothing too harsh at all though. Handling around on ramps and stuff has greatly improved.
MPG Changes:
Around town with a little light highway use has been unchanged and averaging around 19-19.5.
Hwy milage has dropped just a little though by about .5 mpg. This is strictly higher speed hwy use averaging 75-80 mph with cruise set. Mpgs down from higher 18s to lower 18s now.
Getting the 285s mounted up Tuesday so that all is about to change. Will update again.
Update:
MPG Changes:
Any off road usage yet? Curious how that will feel.
Other then a couple of dirt roads, no. It does not soak up the washboard stuff like the stock Pro springs did. Trying to organize a trail run for memorial day right now. I want to flex the suspension fully to make sure I don't have any issues before heading to CO in July. I will report back when I do take it off roading though.
Hmm, that is a worry since there is a ton of that out here... thanks for the info!
1/ What are you running in the back? The Pro version of 5160?
2/ Would you say the front vs the rear feel differently on washboard, as in better/worse? You have 2.5 lift up front and then also 20% stiffer rear springs that are still newish so I wonder if that is part of it.
3/ Aren't sway bar spacers necessary in the front? I mean, you have a Pro, so is that something that came standard from the factory? Or are sway bar spacers something only KDSS vehicles running 2.5 front shocks need to do?
I noticed Radflo 2.5 coilovers come with such spacers as do the Toytec ones (which maybe are just rebranded Radflos anyway).
Thanks, as always!
Yes just the stock Pro Shocks.
I really couldn't say on if it's different front to rear. The front rate was increased about 15%. I'm not sure on the rate of the factory rear springs but they are supposed to be good for only another 100# of load, so 20% may be a good guess.
Yes all of the 2.5" CO kits come with swaybar spacers. Since the Pros already have 3" CO springs then I guess they are not needed. That's a good question. Can't say that I even look at the SB clearance though.
The Toytec 2.5" Boss shocks are Readflos for sure.
I emailed Toytec to see who makes their rear reservoir shocks in the same kit since they look like nothing I have seen but they have not yet responded. It would make sense that they be Radflo but there is nothing like them on the R website. The coilovers do look the same sans the color even on pictures.
If they offer Radflo front and rear I may have to look more closely into them as they are also cheaper than Radflo branded shocks. Not sure I can get over the red and the huge BOSS lettering though LOL Also not sure if they come with customer-specific valving like Radflo branded shocks can.
No Problem.
Yeah I'm not sure who makes their 2.0 shocks either. I doubt Toytec offers them in custom valving though. That you probably have to go to Radflo directly, maybe a local radflo dealer or someone like Accutune. SSO is local to me and they really push Radflo as well. I came close to getting that Boss kit as well.
Remeasured today before heading to the tire shop to get the 285s installed.
Front has settled about 1/2" driver front and 1/4" on passenger. Rear has settled 0".
Had the 285s installed this morning. Goodyear Duratracs LT285/70R17, D Load. Overall it drives great on the tires. They are much quieter then my 41K mile stock Nittos. They do ride a little rougher but not bad at all. I can definitely feel the extra weight and the slight loss of great ratio but overall it's not terrible. Still have to do a little clearencing on the front bumper. I'll see how bad it hits the gas mileage and report back.
