AUX Audio and Video on 2005 Factory Nav
Well as luck would have it, I recieved an email from Coastaletech last night informing me that the product may be defective:
"Hello :)
Thank you for your recent purchase of our Lockpick 2 for your car. It has come to our attention that certain models of navigation systems react differently to our unit. This causes no harm to your car or navigation system, it simply will try to reblock the video screen intermittently and return to the MAP view. There is a plethora of combinations of equipment on any car depending upon region, date, time and place of purchase and manufacture, that accommodating all of these potential variables is a monumental task and is why we appreciate our customer's role in providing feedback. If your unit is experiencing this, please either return your unit for a full refund or you can keep the unit and utilize its other benefits until we have had time to investigate and make upgrades to it. If you have not yet taken delivery of your unit, please refuse shipment, it will be returned to us and a full refund will be given. Or, you can install the unit and see if your unit is one of the units we are referencing. We believe the units in question are model years 2004 and 2006. However, not all of these cars from these model years have this navigation system. "
Mine worked fine until this morning. While watching a DVD, it kept going back to the map screen. :confused:
Although, I did put the nav in override mode and the problem went away. Note sure if that helped, or it was just a coincidence. Either way, you guys might want to hold off until they fix the problem.
how about the other features. Do all work when driving? How about the I Agree screen?
Are you keeping or sending back?
Unfortunately, the lockpick 2 only allows video to be displayed.
"VERSION 2 APPLICATIONS PROVIDE VIDEO AND AUDIO INPUTS FOR YOUR SCREEN AND CANNOT USE STANDARD OR BLUE LOCKPICK (ULTIMATE ONLY). VERSION 2 DOES NOT UNBLOCK BLUETOOTH, DESTINATION OR REMOVE I AGREE"
For now, I'm keeping the unit installed so I can test it a bit more, and hopefully find a way to make it more usable.
http://www.coastaletech.com/APPLICATION GUIDE.htm
Do you have a picture of what you are using to play the DVD's? Will any afterarket DVD player work with this? ...Sorry, ...I'm a little late in the conversation. thanks
hey scotty any updates on this problem you started to encounter?
I actually have a 2006 nav unit but the website says it should stil work. But I wanted to hear from you how its working given you have had some time to play with it now. thanks
-j
Well, as I stated in my previous post, Costaletech.com contacted me via email to notify me that there is the issue with the screen returning to map mode intermittently. I can confirm that this does happen. oddly enough, it doesn't happen nearly as much when the nav unit is in "override" mode. Not sure why this is. Not surprisingly, I have yet to hear from coastaletech as to when they might fix the bug and replace the unit. The bug does affect 2004-2006 nav models so I suspect you will have the same problem. Obviously, the choice is yours. Buy now and deal with the bug until they replace the unit, or just wait until the updated model is released.
The only other issue, is with my ipod. I have the A/V cable connected to my ipod, but the sound volume is very low. Even with my nav at volume max and the ipod at 3/4(any higher and the sound get distorted), it's still at a whisper. I believe this to be an issue with the ipod though. I was able to work around the issue by simply turing on my dvd player and setting it to A/V in, which seems to help boost the ipod signal. I'm still trying to find a way to increase the signal from the ipod, but then again, how much power can really come from the headphone jack anyway....
I wonder if this will work with my DICE unit? I've got the cradle with the video out.....then I could start filling my iPod with music videos. We'll have to see.
Ben
MikeV5280
