From the article it does not sound like they'd work on my '98.
“BLACK” – Toyota 90119-10933; Bolt with Washer. This bolt is specified for the 2001-2002 4Runner, at locations with the protector boot. It is longer than the other bolts, to accommodate the extra thickness of the protector boot. The “11” head markings also classify it as a Class 11T bolt. The captive washer makes this bolt quite different from the flanged heads of all the other bolts.
Everything You Always Wanted to Know About Lower Ball Joint (LBJ) Bolts - and More!
I just used these on mine the other day. They will work without the protector boot without causing any issues. 37 ft/lb torque spec.
