Blacking Out the Runner's Chrome
Looks good!
I'm excited to do this to mine. I am worried about the durability of the Plasti dip so my current plan is to Krylon the front and back and plastidip the door handles.
Nice work.
I've been going back and forth on how to black out my handles. I've decided to just replace them with the trail edition matte black handles. Will cost me more, but I think it will look better and (obviously) last longer.
Looks good!
Nice work.
Just my $.02, but I'd plasti dip everything instead of spotting with Krylon. Here's here's why I say that:
1. The Plasti Dip DIY is full-proof. If you mess up, there's no mess or fuss and no one will ever be able to tell anything happened. All it takes is 3min of rubbing the plasti-dip and boom you're back to "factory default". You can take off the plasti-dip a year from now as easy as you could an hour after applying it.
This is different than the Krylon alternative, because if you want to do it the "right" way, you're best off sanding the chrome handles to prep for paint. Then, if you mess up the project or if the paint fades for one reason or another, the sanded chrome handles will show through and every jabroni walking buy will know there's a disappointed weekend warrior nearby.
2. The Plasti Dip is durable, which was my biggest concern when I was deciding between the Plasti-dip, Krylon, options. I've powerwashed it from inches away to get all the dead dragonflies off, and it also stood up against the guys at the carwash brushing it with brooms. I can safely say that this stuff hold up to normal wear and tear indefinitely and even make it through some incidental direct abrasions.
Do what you want to do though. I'm not trying to change your mind per say, just trying to walk you through my experience so you're best prepared to make your decisions... After all that's why we're all here.
I really wanted to do this too for the durability side of it. Eventually decided against it since I didn't want to lose the Limited's touch lock funcitonality and that pocketing the difference was worth the Plasti-Dip trial.
EDIT:
What kind of price are you finding for the handles?
http://www.toyota-4runner.org/5th-g...92s-ideas-since-mid-2010-a-27.html#post775510
I really wanted to do this too for the durability side of it. Eventually decided against it since I didn't want to lose the Limited's touch lock funcitonality and that pocketing the $150 difference was worth the Plasti-Dip trial.
Yea, if I had a Limited I think I would be in the same boat. But, with the SR5 I'm not super worried. I'll post up some pics when I get it done.
I'm also planning on getting the matte black rear garnish off the TE. Hoping it looks as good in person as it does in my head...
wow, that is sweet. just got the exact same 4runner as yours, just a 2013. really makes me want to do this project in the near future.
cupla questions ...
I've decided to Plasti-Dip my f & r logos and f & r chrome strips:
Cleaning? Just alcohol, right?
Fog bezels? I think I'll order new TE's - seems easier. Is there a P-D color that matches these best?
Quantity? Is one can for each end enough?
TIA.
In the garage right now plasti dipping the chrome handles and skirt on the limited.
I've posted a pic of my first coat below, is it too thick a layer for 1 pass?
Prepped:
1st coat:
I'm thinking it's a bit on the heavy side so I'll make the next ones lighter, but it's always nice to have some reference points.
I did my door handles some time ago and am curious as to how or if you were able to get full coverage behind the handles. My driver side front door is wearing off on the back side. I can feel and see it peeling.
As a lot have posted as well I am not a huge chrome fan. Starting painting these last week. Going to go ahead and paint the end caps on the roof rails tomorrow. Can't quite get the feel for the two tone. Anyway its been done many times on here but wanted to share my pics.
Love our braves tags!
Well I could pretend like i knew what i was doing, but i'll be honest and say I took a gamble that paid off.
The first parts i plasti dipped were the front and rear bumper/badge chrome pieces. One thing i noticed was that the plasti dip became easier to peel as the coat thickness increased. With a heavy layer of dip, 3 or 4 simple rubs back and forth would start a peel. That's why I decided to take a gamble and put a few thin coats on the door handles (just enough to make it look matte).
As for the coverage, I can't say definitively that I have 100% coverage, but i'm pretty darn close- you have to press your head against the glass to see the original finish on the handle. As for the coverage, my spray technique was swiping right to left (and vice versa) across the length of the handle starting with the can pointing straight down, the can spraying normal to the door handle, and ending with me in a squat position spraying the can straight up towards the bottom of the handle. The key to full coverage is thin layers, with the spray nozzle 18-22" away from the handle.
hope this helps
hope this helps
I sprayed plenty of coats on all of my chrome trim. I'd say about seven. I just couldn't seem to get in all the way behind the handles.
If anybody has the correct part number for the trail licence plate garnish can you please message it to me? I think I've found the one I need to put on my wife's SR5 but there's a few different ones so I'm not 100%. Thanks.
I plasti dipped mine today! I also used a couple coats of the plasti dig gloss coating for a slight sheen and UV protection. Came out AWESOME!
Bro that is a clean job!!! I just dipped my rear emblems couple hours ago and I didn't get the end result that I was hoping for. Did about 5 coats with 10minute intervals and i don't think I applied enough dip during my coats (even my wife was nagging saying I didnt.) so when I tried to peel off excess, it didn't come off too clean. Got dip stuck in between letters and such. Just wondering your process on how you did yours?? Any feedback would be amazing!
Thanks man! I did 4 light coats and 15 min between them and 2 light coats of the Plasti Dip Glossifier which adds a bit of a sheen and UV protection so it doesn't fade and IMO looks better and more of a finished look. I also used and exacto knife and lightly cut closely to the letters and emblems so the dip was easly removed with crisp lines. I did remove the front emblem from the truck cuz that was easy.
Sweet thread. I just finished reading the entire thread and couldn't find an answer to one question I have.
If I remove the "4RUNNER" from my license plate garnish are there holes back there? Or will it come off clean?
I was thinking I may simply remove it and leave it off, but I saw someone's pictures of an older one and it looked like there were holes.
I can hear it now... "Why would you want to take off the 4runner..." Not sure... just wondering if I like it without the letters I may leave it off. But I want to know the option before I go pulling the letters off.
The lettering has adhesive on the back.
were you trying to heat the adhesive up before getting it off? I heated it up to get the letters off. Once they were all off I started to peel the adhesive off. At first I started heating it up again, wrong move. The adhesive peels off much easier from the plastic if it's cool. Here is a before and after:
94d4e431.jpg~original
2ee7ba2a.jpg~original
My question is about the holes. Take a look at this picture and it looks like there are holes under the adhesive.
DOES ANYONE KNOW if there are holes under the adhesive on the 2015?
johnpaulll23
