Blackstone UOA
mpaquette
Just changed my oil at 20k and it was my first 10k OCI. I did the first change at 5k and the second at 10k. Anyway, I sent a sample off to Blackstone for analysis. They noted that copper and silicon were elevated. TBN was at 1.8 so the oil still had some life left in it. I used the Toyota 0W-20 for this OCI.
Blackstone's comments: "Your engine is pretty new yet (and it looks like you've been running pretty long oil runs already), so
we're not too concerned about the elevated copper and readings that turned up here. Copper could just be
some residual wear-in stuff that hasn't washed out of the engine yet, and maybe silicon is from factory
sealers. Because other elements look fine, we doubt either element warrants any attention at this point.
Averages are based on 5,200 miles on the oil. The TBN of 1.8 shows some active additive left (1.0 is low).
Check back for improvements next time."
I'll post the actual element numbers later today if anyone is interested. All in all I'd say they look decent for a 10k OCI. Probably will post this over at Bob is the oil guy to get their feedback.
Synthentic? (I always use synthetic so I don't even know if you can run regular oil in the 4runner... :| )
Very good! Thanks for the numbers as this should probably change a few minds (probably not though) on trusting the 10K synthetic interval. One question: What was the time interval between 10 and 20K? That will have some bearing on analysis but probably not much. I am a firm believer in 10K changes unless most of that 10K was spent towing or off road.
The oil was in use for almost 9 months (1/23/11 - 10/9/11).
Here are the numbers from Blackstone. Note that the averages listed are from Blackstone, but are for 5k OCI's. The column labeled "unit" are from my oil.
I also posted this over at Bob is the oil guy, here's a link to that thread if you're interested.
Code:
Miles on oil:	9,925
Miles on unit:	20,039
Sample date:	10/09/11
Make up oil:	0 qts
		Unit	Averages
Aluminum	5	3
Chromium	0	0
Iron		19	11
Copper		16	6
Lead		0	2
Tin		0	0
Moly		627	78
Nickel		1	0
Manganese	1	1
Silver		0	0
Titanium	0	1
Potassium	0	2
Boron		64	40
Silicon		34	16
Sodium		8	33
Calcium		2381	2252
Magnesium	10	76
Phosp		716	684
Zinc		852	817
Barium		0	0
SUS Visc @210F		53.9
cSt Visc @100C		8.45
Flashpoint		400
Fuel%			<0.5
Antifreze%		0.0
Water%			0.0
Insolubules%		0.4
TBN			1.8
Are all synthetics created equal?
Is Toyota oil pure synthetic or a synthetic blend? I'm not sure if all synthetics are created equal, but I have a friend who's a BMW mechanic who told me he tore down an engine from a X5 (using pure synthetic) that had gone 30k miles without an oil change. He said the internals looked brand new. I'm not saying 30k is a good idea....just a testimony regarding synthetic oil.
phisfunk
