Brake lines for Tundra upgrade
was that directed at me?
i said vented, not drilled and slotted.
an 85 runner originally has a solid rotor, very thin and shitty.
i meant drilled and slotted.
but no i was just making an ignorant joke saying how drums on all 4 are the best.
I think I would upgrade to a larger master cylinder before I put on SS brake lines. I love my 231mm Tundra brakes, but how far the gas pedal goes down before I start getting brakes is a little weird.
Yeah seems like you are almost accelerating when the gas pedal goes down.... :bolt:
I figure ill do extended brake lines now So I wont have to bleed again later as i would like to do a 2-2.5" lift in the future. Anyone have a good recommendation should I go braided? Or what other options do I have? Thanks!
IMO...Your truck is a 2000, so the OE rubber lines are probably starting to crack a bit. If your already spending the $ to upgrade, new braided lines are only ~$75. You'll already have the callipers off, so you're one nut away from changing them anyways. I got these ones..Performance Front Brake Line Set
Were they a direct fit? When I worked for Lexus a customer had us do some work on his IS300 including stainless brake lines and they had no way of fastening them to the OEM brackets.
+1, would that be a direct fit on a '01 SR5? And is there any other hardware I'll be needing for the TBU? (relating to the brake lines)
Yes, they are a direct fit. The retaining clip locks them in.
Should be the same for '01. You dont need them either. Your OE steel lines will connect directly to the callipers.
Jesse1
