Brilliant's Mod Thread
I was wading through your build (sweet rig!!) and was wondering were you acquired the 115v plug in this picture (top most). I know it's been a couple years since you did this mod, but I'm looking for something similar for putting an inverter in the back. I'm assuming its a three prong plud underneath that cover. Cheers
The plugs are from a Pontiac vibe or Toyota matrix. They're two plug. For low wattage 3 prong I carry an adapter plug.
Mostly I use them for charging small things, like handheld radios.
4Runner is looking good. How are you liking the lights? Are you still happy with the purchase? Also, any chance of getting a direct link to the lights you ordered?
Love the prtojectors but having issue with the TRS controller shorting out. I'm on my third one but also ordered a eBay simpler dual relay harness. Issue is running high beams for hours ends up faulting the trscontroller.
Hilux 185 is what you are after. ???? Toyota Hilux Surf 185 ("?????????? ??????"), ???? ????? :: Rumin Sport - ????????-??????? ???????????
Cool! How were the dunes? Is that in Florence?
Dunes were OK but no one there and I wasn't feeling very brave. Pretty low angle sand heated the trans up so I didn't do a whole lot. I got enough in to test out the new bumps though, nice to have the front end more controlled.
You're wiser than me... I aired down to 16psi and charged in blind. My wife encouraged me to climb one of the larger dunes to take a pic on top. There was a drop off on the other side, so I turned to follow the top of the dune and got stuck with a rather large drop on either side and nothing to winch off of but small trees. Pulled a few out of the ground, the last one held long enough to get me out. VERY lucky. No one was out there (it was a Tuesday) and it was a longgggg walk to find anyone.
I think I am going to order some of the wheelers bumpstops for the newer Tacomas... That deal on the chubbys was still a bit steep for me.
I was thinking of you while out there. :) I read your post on how you got stuck a while back. My trip was a lot of pavement, with a few small excursions. I had nothing on me to get out and with just 2 people on rental quads, I knew I'd be walking. I had my OBA malfunction so I didn't want to air down either.
Getting the front bumps was a total impulse buy that I questioned later. The rear is nice to have so you dont slam it full of gear and that was the most noticeable upgrade.
Soak your OE bumps with PB blaster for at least a day. You'll need a 3" jaw pipe wrench to get them off. HF sells one for about ~$18. The factory bumps were a pain for me to get off.
Very impressed...especially with your use of OEM switches and the fabrication of the blanks...Super clean. Adding some of your ideas to my to do list as we speak.
How were you able to order the lights from a Russian web site?
Fridge
After a long road trip last year, I've began casually looking at fridges.
One of the things I didn't want is a large fridge. I didn't want to dedicate a bunch of space, a slide out tray, and so forth. I only run two small coolers today, and those fit behind the seats. I was after something similar to my existing coolers. I came up with a Dometic/Waeco CF-18 fridge. Big enough to cool a few cans, and keep all the meat frozen/cold.
I tried it out the other night, froze solid 2 quarts of water in little time. Turned it off over night and had about 50% melt overnight. After 24 hours, it was down to 75%.
I also added 2 aux 12V ports on the right side rear seat for the fridge and for a charger for cell phones at night. I used some tacoma sockets and its wired to a relay/switch.
AIL4fc9qugjyJPh17qOH68rMDpkL_s6NDjlVOZAVV-lXYgTv4NjQYVA0fRcXdaRNQr9ZQIyKBmxb_ungBbjCE4QDPtTPgXQd_4VwMXqann9Z1zr2INieaIUZuYt4lfHNrsXUAo-9pJJ5y7REO6zjJeyzi5AF_A=w482-h857-s-no
AIL4fc8te9_wog1a_O35QFnGOPCQAPhb3iIoyhB__sHqr_G3QPsuwnP0SPakQsGl-kiei4q_Jw7-z8tivev_EThk9kjpItmnyrty7tnt4ypXHxGC9RcG72pH44Y4sOqa-McyfdQGfLyZfFdK93-zYjcqgZ5IHA=w1521-h857-s-no
Spent the day fighting with a Chinese HID harness. Found out the harness had a short in it after nothing making sense and an hour at it.
Given the switched grounds I had to swap wires and resplice the relay. The easiest way to explain it is the relay selenoids become the load rather than the bulb and completes the circuit. No more morimoto harness, so now maybe I CA. Have high beams on for hours without cooking the controller.
Saving space for aux tank.
I want to add about 10 gals or so.
The only technical issue I found with an aux tank is integration with the main. I've seen a lot of really complicated discussions, and its really not that difficult.
I'm going to use a prado 90 style filler top graphed onto a 3rd gen tube. Its a hole/tube for each the main and aux tank. A simple switch to control a pump from the aux to a tap on the main fill tube. No issues that way except a bit of time to pump from the aux to the main. Overfill just recirculates but cant overpressure anything. AU designs are like this.
I've got to drop by death's and get a tube to modify. The tube is the only piece that will require much effort I think. The other time sink will be the gauge.
Prado 90 filler (right side pic 1)
T ap to the main fill tube looks like this
My OE sub tank switch from down under
variable resistance and set points red LED gauge I will integrate with the aux sender and put in an OEM switch blank.
whers did you get all the 90 parts?
erinobr2000
