Busted key fob case
After 30 min of searching and googling, I found this thread. Mine fob's "ring hole" broke. I couldn't find a replacement cover anywhere.
Yeah, easiest way of fixing this with the RS3000 system is to get a new remote from mykeylessentry on ebay. I got one and it works great. It doesn't look as "stylish" as the original but at least it can withstand a drop, and it's only $15.
I drilled a fishline sized hole through the keyfob and then went to a jewelers shop. Bought a thin lined key chain attachment that has worked ever since.
If your fob is the style jij posted above (my 2002's is) you can get a replacement case from Autozone made by Dorman.
They don't make one for the 4Runner (that I can find on their website - www.MyKeylessRemote.com) but they do make one for a 2002-2006 Camry that is identical except for the small inner ridge on the bottom of the fob. Part # 13614, it's $15.
You will need to Dremel away the ridge on the inside back cover where the battery holder is attached to the circuit board (it will be obvious to you once you put the circuit board in the new back cover) but that only takes about 5 seconds.
They even had the button battery (CR 2016) so in 3 minutes I was all set with a brand new fob.
I got this tip from Mountain in another thread but tought I'd post here as so many are asking.
Resurrecting this old thread to post this link:
2 New Replacement Keyless Entry Remote Shell Pad Glass Case Key Fob Fix Repair | eBay
I just got mine in and they were a direct swap over, no modding needed. They look almost identical to the factory one and were $13 for a pair. Swap over was less than 30 seconds and they work great.
I got my replacement three button remote from wireless-now on ebay two years ago, and it works perfectly.
Looks like they are even cheaper now ($19.95 w/ free shipping) and the empty shells are $8.95/ea or two for $13.95.
ebay seller wireless-now
Is there any way to aquire the OEM case without the motherboard stuff inside it? Mine still works but I need to carry the remote separately.....
I'm OCD, I like the Toyota signature on the remote.
matisgugle
