Cheapest way to mount a front-mount winch?
SHOOTER!!!
If you have a fat-lip bumper, just mount the winch behind the stock bumper on a winch plate welded to the frame rails. clean and cheap
That is excellent!! I want that. No, I don't have a fat-lip bumper.
Or if you don't have a fat lip bumper you could just extend the frame rails 3in and bolt on a winch plate like this. But then you are kind of screwed over on mounting an aftermarket bumper
Even that would be outstanding on my truck. I like the simplicity of the stock look and simple install. Very much custom though.
I like to do that for stereo installs in my cars. I put in great components, great amps, and a setup that sounds amazing, but I use the factory install locations and factory speaker grills, so nobody can see that anything was modified :)
Did you have to modify the winch plate to fit properly? I am not a welder so is it pretty clear cut how to mount if I take it to someone? Does the frame need to be boxed off?
I know 4Xinnovations is working on a bolt on hidden hitch, but that will be a while out yet. If you can wait though that is what I would do.
I had to trim to minor tabs with a grinding wheel. I took it to a local fabricator to actually weld it in. He added a few gussets/braces. Unless you weld, you'll probably need to find someone who does to help.
Hidden winch mount
Do you have a build write up for your winch mount? I want to do this on my 2000 Toyota 4Runner. Does it take any cutting?
Accessing winch?
Great post! Thx for the great idea of winch with stock bumper. This may be stupid, but how do you access the winch controls with this setup? Thx
I
