Chuckles89
I had one desintergate as well, if you find ones that work, they will probably be the lower rear trailing arms on a second gen.
on the third gen the rubber for the upper trail arms is the same diameter as the bottom, but the bottoms have a metal sleeve on them. however i went to a junk yard and the second gen upper and lower links are the same size and both have metal sleeves, they make a kit for the second gen rear bushings in poly so i think this is a possibility.
So a rebuild kit for the lower control arm on a 3rd gen (2-3 feet long things on the bottom of the axle) will fit the upper control arms (1-1.5 feet things on top of the axle)?
And a 2nd gen upper control arm will fit a 3rd gen? You're saying that maybe the 2nd gen rebuild kit will fit a 3rd gen if the bushings are burned out?
