CO_FlyFisher
I bought one of the LED 3rd brake light units, and installed it over my Christmas break (I've been very bust since then). I ordered the red one. It matches the LED tails very well, especially since it has two rows of four LEDs across which is the same number across as the tails have.
I peeled the foam tape seal off of the factory light and put it on the LED unit. Also, I checked and the factory lens DOES fit this aftermarket housing, so if you wanted to, you could use the faceted factory lens. After looking at both, I decided the translucent red lens that came with the LED unit looks better though, as the faceted factory one diffuses the LED light too much and doesn't look too much different than stock using a bulb.
GREAT find!!! About time someone came out with a LED 3rd!!!
