Do I dare ask what this was? More rust!
you got the idea...
I've painted my rear end a couple of times, as soon as surface rust shows. My son recently bought a Mitsubishi Eclipse and it had rust. We took a week and removed as much as we could (pretty much the whole front end) and wire wheeled, sanded and scoured everything. We applied 2 coats of POR15 with an over coat. I'm reasonable pleased with the results. In you case, that is really, the route to go. However, on the pan hard bar, both ends, if you've lost more than 40% of metal thickness, I'd consider grinding and welding some plate to strengthen it.... if not, I wouldn't off road it too hard. most of the rust remediation can be done in your driveway but it requires time and lots of elbow grease! Good luck!
where did you go shopping for a rear axle??? I didn't think it could be that straight forward.
I poked the area with a screw driver, it didn't fall apart so I assume there is still meat left .
So far it seems like it hasn't rusted through, except the cast they put on the frame is starting to fail all around the car. I guess taking it all out, and aplying POR 15 or something like that should give a a lot of life left.
Just seems like a huge pain in the butt
I found the axle on craigslist
Okay,
Here it is ... More pictures of rust of the car. brace yourself
https://goo.gl/photos/aegxKJPJfmD1ySaB7
I died a bit inside. Nothing looks like through the frame rust. Granted I didn't take these pictures, my dad did.
What do you guys think???? New car time??
Edit : Should I post pictures one by one or is the google drive link good?
patnewton
