Yes, I used the switch that came with the kit, looks good and easy to install. Did not want to deal with factory switch setup. I am sure there is a way but would require a lot of digging. On a limited you would use your factory fogs switch for fogs and new switch for DRLs only.
[MENTION=166470]itr1275[/MENTION] did you try using the tape instead of bending the pin? Can you post some pics if you have done that.
I know it's been proven here again and again... But I Just wanted to let you know, It worked for me. Non Auto light switch 2016 Trail. :high5: All lights work, DRL disabled but moving the pin as shown on Page 4 of this thread. If you still have your doubts. Rest assured. Light bending of the pin out of the way will be easy to bring Pin back into place if you would like the DRL to function again as shock, without having to buy a new Relay.
YES, but does this work on the 2017 and 2018's?
[MENTION=175559]Kdawg[/MENTION],
There are photos here to compare your T4R relay and power distribution fuse box to, just look at everything to confirm.
As [MENTION=150517]Terbston[/MENTION] stated, I would not see any reason why it would be any different on your year T4R...
Great! I will check out and confirm this evening. Thanks.
My 2017 TRD Off Road has the option to have:
1) all lights off
2) DRL on only
3) Parkikg Light w/DRL on
4) Regular driving light w/no DRL
Because I’m installing the amber grill lights tapped off the parking lights, I’d like for just all my ambers (side markers & grill) to light up when switched to that position without having DRL come on. I aslo don’t want to lose the option of having my DRL when switched to that position. Is there a way to disable DRL when parking lights are on?
I don’t think you can have both situations, otherwise some of this thread would not exist.
It’s either have drl on when you go to parking light position or disable drls unless someone has found another way to mod them.
DRL Disabled on Non "Auto" Headlights System on my SR5 Premium.
So disabling them is the same as Auto Headlight systems, by bending pin #2 out of the way without any adverse issues!
I used a pair of needle nosed pliers to bend the pin down and firmly to the side as pictured.
DRL's don't come on.
Parking lights function as normal.
Low Beams and fogs function as normal.
High Beams function as normal.
Tail lights, stop lights and turn signals function as normal.
Thanks to [MENTION=4160]KDCane[/MENTION] for starting this thread!
Thanks [MENTION=123179]Kc_fan[/MENTION] for trying this and taking the photos for the rest of us! :first:
So, here are my photos of the relay and the parking lights on and NO DRL's !
Thanks for this.
So will this allow the DRL to be turned on and off, or just disable them completely?
Thanks,
