Dropzone's 1994 4Runner Expedition/Overland Build
since the portable compressor unit will run an air ratchet i picked up this compact air ratchet off ebay, it was a good score, new for 1/2 of what they want for it at Home Depot, 500 lbs of torque, it didn't even skip a beat taking lug nuts off and only weighs a couple of pounds
2017-09-28_01-18-54 by ocdropzone, on Flickr
2017-09-28_01-18-38 by ocdropzone, on Flickr
dug out an old storage box i had in my old Tacoma. Used it to consolidate 3 rubbermaid action packers. Better organization and takes up less space
2017-09-28_02-06-35 by ocdropzone, on Flickr
22 year old headlight housings suck
install is pretty straight forward, remove the corner lights, remove the grill install and re-install the other junk.
I went ahead and pulled a PIAA H4 headlight harness from the trekker and used it with these headlights (which use a H4 bulb)*
Daylight they definitely seem brighter. *Will get them aimed tonight see what the verdict is.
Just put these same headlight housings on my truck, but I went with GTR Gen 3 LED bulbs since they mimic the filament in a regular bulb. They definitely rock. Did you keep halogens in it, or have you switched to led?
What lift did you use??
Up Front:
-10 year old Trail-Gear Leaf springs from my old 81
-Low Range Off Road Low Profile front spring hanger
-Sky's Off Road Boomerang front shackles
Rear:
-1997 FZJ80 Rear Coil springs
-1" Daystar coil spacer
Great looking truck Dropzone!!!
I am running LED's, the bulbs that I installed sound similar to what you have installed, I bought them about a year ago through my daughter's boyfriend who works at a local NAPA
the beam pattern is ok, wish there were a few more options available with doing a projector conversion
half the reason to get the 4runner was to haul my grandson around
today he decided to test 23 year old switches and buttons
2017-10-06_04-24-12 by ocdropzone, on Flickr
2017-10-06_04-24-34 by ocdropzone, on Flickr
I think he did about 3 years worth of button pushing in 15 minutes
than he saw his mom get off the train
2017-10-06_04-24-50 by ocdropzone, on Flickr
can't make up my mind on what I wanna do for lights...i really hate roof lighting so i like to have stuff mounted up front
pulled the round stuff
2017-10-06_07-37-18 by ocdropzone, on Flickr
mounted this fog/spot combo
2017-10-06_07-33-11 by ocdropzone, on Flickr
had to mount it high enough to clear the in/out selector on the winch
the 3 modes put out a ton of light in a compact size
2017-10-06_07-34-05 by ocdropzone, on Flickr
still need to paint the mounts
ordered a new grill today too...the one i had i had trimmed to clear the winch solenoid box and my spare grill(on truck now) is pretty well toast.
Threw a new grill on the truck today. 9ld one was about to fall off.
Don't like the chrome but the weather would not cooperate today. Will scuff it up and get some black paint on it later
A few weeks ago i accumulated all the stuff (grill, headlight buckets etc) to convert to a set of Truck Light LED's. I had those in my Trekker and loved them. Started pulling everything apart and found it was going to be a major PITA to get the buckets to mount with out:
1) half assing it to get the buckets so they would have some form of adjustment
2) changing the core support
neither was gonna happen so I went ahead and looked at this 2nd Gen head light thread
bit the bullet and ordered the LED's, spendy but recouped a lot of the cost returning the headlight conversion parts on amazon
GTR bulbs came in saturday morning, installed them that afternoon
the usual PITA pulling the grill off etc
2017-10-21_05-23-41 by ocdropzone, on Flickr
old LED compared to the new. The GTR is definately better built
2017-10-21_05-24-00 by ocdropzone, on Flickr
old beam pattern
2017-10-21_05-24-36 by ocdropzone, on Flickr
new beam pattern, much better and well defined compared to the old one
2017-10-21_05-24-20 by ocdropzone, on Flickr
need to play with the adjustment a little bit but the overall improvement is great
as many of you know I have gadgetitis really bad.
Oregon recently enacted a pretty harsh distracted driving law..pretty much don't touch your phone or other electronic devices even at the light.
So upgraded my dashcam to a Garmin dashcam 55.* Nice thing is it is voice activated and has wifi built in so you can download straight from the camera to your phone
i need to pick up the hard mount cable*
it came in handy today when a blind lady wandered out into the insection (click to play)
GRMS0001_1 by ocdropzone, on Flickr
takes good pictures at night and during the day
2017-10-27_11-50-30 by ocdropzone, on Flickr
​​​​​​​2017-10-27_11-50-56 by ocdropzone, on Flickr
That Trekker is rad! But I can't argue with the functionality of that 2nd gen
Thanks, it was a great truck and project for 8 years...
took a little road trip to Seattle yesterday and picked up some stuff
20171104_142707 by ocdropzone, on Flickr
The awning will go on the rack I have.* I have plans to rework the rack to get it lower.
20171104_144339 by ocdropzone, on Flickr
I'll have to figure out how to mount the box and will use it as a base for a future sleeping pattern.* *might see if I can extend the drawers so the two bigger ones go to the back seat
Sweet! How does this thing run btw? Auto and 3.0 still doing ok?
still going strong, about 15 mpg with 35's, 5.29's and just over 200K.
not as much get up an go as a manual R150 but for what I have into this truck I can't complain too much.
I would love to a 3.4 or 1UZ sometime
leolediola
