Easy Weekend Mods
Yeah, that's an impact driver, not an impact wrench. Not quite the same thing. I mean, functionally they are similar, but 1600 lb-in is not very much for breaking loose rusted nuts. Can't say how much more you'd need, but a typical full size impact wrench is in the 400-1000 lb-ft range. And some of the smaller ones are still double the torque of your impact driver. If you already have an air compressor, and air tool would be pretty cheap. If not, unless you plan to do other work on your 4runner yourself, it's probably not worth investing in a real impact wrench just for these bolts, because even the cheap ones aren't "cheap", so your best bet would just be finding someone who has one.
I went through basically exactly this with my running boards. Couldn't get the bolts to budge with my 18 volt impact driver, and had to use my friend's air impact to get the bolts off. And after that I bought an impact wrench as soon as there was a sale I liked.
i do happen to have an air compressor but the only other time i think id use it is for suspension and all the nuts in the suspension look pristine
If you plan to work on your own suspension, an impact wrench would be pretty important. Even just lug nuts are kind of pushing it for an impact driver. Most of the time it will work, but sometimes it just... won't. Especially since you have to use 1/4" hex adapters. Since you already have Ryobi 18v battieries/charger, it's probably easiest to just buy a Ryobi 18v impact wrench with no battery or charger and save quite a bit, even if they're not the greatest. At least that's what I'd do in your situation.
Wanted to share some super simple mods that I have had on my 4runner for some time now:
1) Covercraft Custom Fit Sunscreen ($55.00 amazon) Have had it on my 4runner for about 7 years now. Easy to fold and custom fit, has been super useful going through three digit weather for months each year.
2) Drop Stop - Car Seat Gap Filler: ($19.99 amazon) Have had them for about 4 years after seeing these on SharkTank. They are awesome as I hated my cell phone or anything else sliding out of my pocket and falling through.
3) Smokers Kit: ($25ish ebay) Love having a second car charger outlet and the change storage area can be pulled out easily to empty it.
4) Lexus IS300 Shit Knob: ($30ish) Serves no purpose besides being nice to look at and feels nice to shift with. Have had it on my ISF and then now on 4runner.
Thanks for the smokers kit idea! Just installed it last week and love it!
Polished the headlights on my 06 and put it done Lastfit H11 LED. Not the best output but better than halogens.
Sent from my Pixel 2 XL using Tapatalk
Wiring help plz.
So since I’m new I can’t make a new thread, so apologies.
I just did the fog light mod1 and mod 2 and the usb charger mod in center console.
So for some odd reason my aftermarket remote start and alarm no longer is responsive. I was very careful not to mess with any other wires or take anything out. I’m wondering if the fog light mod #2 (under the steering column) may have blown a fuse on the alarm control module??? I already double checked all fuses on the Toyota interior-nothing burned out. I removed the Mod #2 and it did not come back.
Anyone have any ideas? Thanks. Appreciate in advance.
2007 4Runner
2007 4Runner
There are also fuses under the hood. in the engine compartment, near the battery.
My wheels on my "new to me" 2006 are kinda buggerd up. has anyone tried this on their wheels?
I'm assuming you're asking about Plastic-Dip on your wheel, if so the answer is yes, many here have used it to re-do the finish on their wheels, if at some point you want to change it later for whatever reason it will easily peel off.
Do a search for Plastic Dip/wheels and you should find a lot of info on the subject.
Hey all.
I just acquired my 2007 SR5 and I've seen scattered mentions about headlight bulb changes and in searching around I've seen various answers to this.
What can I do to make my stock headlights better in terms of changing out the bulb? The stock headlights are not good.
Hey all.
I have been curious as well. Would be neat if we had a thread comparing all the options
Sent from my SM-G950U using Tapatalk
Is there an "Andy mod" for 4th gens? I searched with no success. Thanks
Hitting the center diff lock button turns off some nannies, just don't do it while turning on concrete. Snow and dirt is fine.
You can unplug a wheel speed sensor connector in the engine bay, driver's side.
Or you can splice into a wire somewhere and add a switch.
Should be quite a few write-ups, we don't really call it Andy's Mod though.
what would we search for? Ive tried and came up with nothing
Thanks in advance
