Eibach Pro-truck lift
Shocks: 4 Eibach Pro Truck, fronts are installed on the bottom ring.
Front Coils: Dobinsons C59-302 (advertised at 2.5" lift)
Rear Coils: Dobnsons C59-325 (advertised at ~2.0" lift)
Stock Hub measurements (I have 3rd row seats):
PF & DF: 19.5
PR & DR: 21.5
New Hub measurements after 50 miles, rears should settle with some time:
DF: 22.0
PF: 22.5
DR: 24.0
PR: 24.0
Compared to my OEM XREAS suspension with Toytec 2.5/1.5 spacer lift, this lift feels slightly better in terms of ride quality, but not pleased overall as its still a bumpy ride on road. Off road is much better though.
I went with this lift set up because I wanted the lower spring rates that Dobinsons offers as well as being able to dial in the perfect lift numbers for my needs and the Eibach shocks have great reviews and the mono tube design is what I was after. My end goal was really to get the smoothest on road ride I could get and I did not achieve this, lol. I do have a slight driver side lean that I will address with a top plate spacer after a couple of months if it remains. Also my XREAS lines are zip tied currently and I plan on removing the system soon.
Let me know if any of you have any questions!
Been searching on this thread but couldn't find confirmation. Anyone running the Eibach 2.75" coils and 1" coils on Bilstein 5100 shocks ? How does it ride, and any pictures ? I have 5100s currently at .85 setting up front with stock springs, and stock rear. Looking to get Eibach lift springs all around for more lift. I don't mind the way it feels now, stiffer than stock, just wondering how the ride will change swapping the stock springs to the Eibach lift springs. I'll be resetting the Bilstein back to the 0 setting for the Eibachs. Thanks !
Just ordered my Stage 1 from WheelersOffroad. Can't wait for it!
You'll be waiting for it. I ordered the Eibach lift from them too... waited and waited for confirmation. I eventually called and was told they were out of stock. I canceled my order. Hope you have better luck with that company.
I spoke with Tanner today and he said he wasn’t sure, that generally the damper team just preloads the spring enough so it doesn’t roll around. In other words you should plan on installing, getting it on the ground to check everything, then jacking back up to set height you want. Mine should be here this week, also ordered JBA UCAs.
Did you get these in yet?
I still can't get an answer from Eibach. Even though marketing said you can adjust on the rig, tech support said I could.....but, one needs a spring compressor. Tech support has no clue what compressor to buy. Anyone have a clue? The regular ones harbor freight do not fit into the spring, they are wound to tight
Sorry to hear about this and wish i could help. Furlough life.
Call and ask to speak with Mike Seidman. He’s the R&D manager.
Ryan
Not yet, have been waiting for my UCAs. Will go in on Monday.
That’s a bummer. Last week I was searching too and just like you, sold out everywhere. Until I found wheelers off road showing “in stock” on their website. On June 10th, I called and received verification they had 12 in-stock. Bought it online and took advantage of their 10% off for first time customer deal and received on Friday June 12. Installed it Monday and loving it so far. Need to do an alignment but waiting for new tires to arrive.
What's the code?
Had my order canceled and refunded by Eibach last Friday. Ordered from Toytec Lifts on Monday, shipped today. Hope to install it some time next week.
I ordered from Wheeler's on Monday, called them yesterday to ask if they were in stock and was told "yeah they're in stock, we're just a few days behind because of covid and they're probably going to be assembled soon and shipped out soon afterwards." Today they emailed saying they were out of stock. So I called and cancelled and ordered from Toytec. Hoping they ship soon... I had a punctured tire and have been driving on my spare all week. Puncture isn't fixable and I need new tires anyway but need the lift so I can put on 285s.
I experienced the exact same issue with both YotaMafia and Wheelers. Ordered through Toytec and they had it shipped 2 days later and at my door in like 4-5 days. Not sure why these companies allow you to purchase, tell you it’s waiting for assembly, all while they never had the product themselves.
I let the Eibach settle a few hundred miles and have now Upgraded to 17x8.5 -6 and 285/70 Falken . I have JBA’s with Caster at 4.2 , slight rub fully cranked in Reverse.
ff380f923cc52cecf5460f325bca6436.plist
Sent from my iPhone using Tapatalk Pro
Installed the kit a few weeks ago with a buddy and it feels great! I have about 300-400 miles on it and am noticing the front drivers side leaning.
EDIT: just measured and it’s not as bad as it looked with eyeballing it.. seems the drivers side is lower by about .25”
Can someone confirm if the springs look like they’re seated correctly?
Driver's side
Passenger side
Hey Ryan,
When are the TRD Pro Fox front springs coming out?
Used to be up on their site for a bit. I saw the link is now dead and the product was removed from the site for now. Lots of people seem to be waiting on this product to be released.
I’ve had my Eibach pro truck lift installed for little over a month now and have been very happy with it. Self installed and was actually pretty easy overall with the help of a buddy. I’ve taken it on some easy-moderate trails and it’s handled very well. As said by others, it rides a lot firmer than stock so most bumps go over pretty smoothly. The overall quality is very impressive too so it gives me extra confidence in its durability. Also the 2.5 inch in the front and 1 inch in the rear levels it out pretty evenly and gives me enough clearance through most of the trails I’ve checked out so far. Even with stock tires(which is my next upgrade), having the lift makes a huge difference IMO for the average off-roader.
delislerebecca
