Eibach Pro-truck lift
Sorry, but I don’t know the exact answer. My assumption is about 2.5” out of the box with no adjustments based on what my shop told me.
Thanks. Was there adjustability above where it came preset? We’re there exposed threads above where it was preset to? Thanks
My 1st mods other than stock size Falken Wildpeak AT3W's were a TRD skid plate, Warn Winch and Warn Bumper to my non-KDSS Off Road.
My Eibach lift was installed on the lowest clip setting back in July of 2019.
Home from the dealer:
200lbs of Warn winch with steel cable and Warn Bumper - note the sag.
Eibach Pro Truck Lift installed on lowest clip.
How it sits 1 year and 5 months later with the addition of HEAVY Shrockworks steel armor (sliders and skids).
The ride is fantastic on and off road.
So I installed the kit on my '17 trd off-road along with JBA UCAs and im a little disappointed at how much rake I maintained. Installed at first notch, and after an alignment and driving several hundred miles over a couple weeks I measure ~21.5 inches in the front and ~22.5 in the back. Everything on the front end is stock. Did I do something wrong??
I'd like to upload a pic but struggling with resizing to " 136kb"...
Something is definitely wrong there. I measure a little above 22.5 in the front; 2018 ORP w/ JBA on lowest clip.
Have you attempted to “screenshot” your pic for the resize? Sorry for the obvious tip but worth a try.
What really changed your rake then...i think im missing something..lol
I think I could probably go up a setting on the front shock clip with all the weight I have but am happy with the way it looks now. I also like having the full range of motion of the shock.
Can I get some help!? Haha, eibach pro lift on 184r with 3rd row on 285/70/17s... fixing to add a bumper and winch. Should come up to no more than 162 pounds total. I currently am on the Lowest setting and the coils the kit came with.... I want to switch out the springs in the rear for Dobinsons 2 inch spring and bump up the front to the 2nd or 3rd setting . Any insight on this ? My vehicle doesn’t even look lifted anymore with 285s!
Everything has finally arrived!
I didn’t know you could switch out the springs on the eibach kit! I want more out of my eibach... 1 inch in the rear isn’t enough . How’s this set up working for you? I want to bump up my front a clip setting or 2 and replace the rear 1 inch springs with dobinsons 2 inch springs.
I've only seen a few pictures on here with stock coils (Front/Rear) & the Eibach Pro Shocks set to 1.6 setting in the front, wondering if anybody else is using this setup? Pictures would be appreciated!
1.6? The eibach pro lift is a 2.75 inch front lift at the lowest setting and a 1 inch rear . Maybe it’s 1.6 with factory coils??? I’m interest to see if I can replace the eibach with a different brand .
Sorry I misread your post , I’ve got the entire eibach pro kit installed, wish it was a tad taller ... like a 3 in front and a 2 inch rear .
Here’s the entire pro lift kit on 285s. Trd wheels. I’m going to replace the 1 inch rear coils with dobinsons 2 inch coils and then bump up the front 2 clip settings .
I used the factory spring at 1.6. I looked for a shorter new spring but the only one I could find was a Dobinsons. I would have tried it but it only came in teal.
I’ve heard of people using RADFLO, ICON, dobinsons on the eibach for the rear. Obviously rad and icon are going to be closer to $300 for a set . I’m thinking dobinsons for my ride.
No worries! Love the way these trucks look with the full Pro-Kit (Shock & Spring), but I'm looking to only do the shocks right now, which have a Ride Height Adjustable perch up front...similar to the Bilstein 5100's I believe.
I've seen two members post pics with this setup, claiming about 1.6" of front lift, which would level the truck. It also gives the opportunity to add the springs for additional lift later if I change my mind. Looking for some more side profile shots of this setup.
Great looking car! Do you have additional weight up front?
I actually just did this with mine... didn't want a big lift but just to level the truck, so only replaced the shocks and used the 1.6" perch. Based on eyeball measurements, it's very slightly forward raked (I have sliders and a front skid installed). Next time I park somewhere level I can snap some photos. I really like it though.
This is with factory springs and front shocks at 1.6. The rear has the 4th gen spring for 3/4”.
Awesome, can't wait to see it. Happy with the overall outcome?
delislerebecca
