Fan Climate Control Illumination Out! - Bet you can answer this!
sant6236
Fan Climate Control Illumination Out! - Bet you CANT answer this!
The illumination is out on the fan control lettering on the climate control panel.
NOTE: However, the Low, Med, High indicator arrows stay lit.
Is this indicative of a bad bulb?
See photo below:
You can easily replace it yourself. Yes, it is an indication of a bad bulb. The reason the indicator light around the outside of the control knob is still working is because separate bulbs are used.
Try looking at this:
Center Console Lights
You need part #90010-09015
Once you open it up, its located here:
consolelightbulbs010.jpg~original
i have the same problem but its the auto,ac,up temp, and down temp (the middle gauge). is there a place where i can buy white bulbs and change out the yellow?
