Excellent article! I was wondering if it is possible to leave the transfer case (TC) in place and just split/remove the rear half of the case only? That might save some time and heavy lifting.
I must commend MandAtaco for the best write up on the net for this, not involving an actuator tear down. Stay away from all those pull twist and crack articles, the info dosen't even apply to the two shaft actuator.
You can buy new actuators from the OEM who is AISN, not TMC, Dorman is even selling them now, not sure if they are just repackaged AISN units.
To answer Gdmeaders:
Yes, did it once the hard way, it is unruly and unbalanced and dropped it 3 times. The next two times I split the case on the truck, just beat the case with a dead blow until the RTV released. Pull the unit straight back until disengaged and lower it to you chest. This cuts the weight in half and is way more manageable when doing it without a lift and tranny jack.
Tips: you may tear the front shaft output seal so have a new one handy, can install from outside b4 pulttng the flange back on. Toyota may have an error online as seal supplied has huge flinger flange on it, so I removed the one pressed on the output hub for now.
When unbolting the front shaft, remove the grease fitting so you can compress it easier, will shoot grease so cover w/rag.
Make sure you recover the 2 halves of the split needle bearing and thrust washer, put back in place prior to putting halves back together, a handful of grease lathered on it will help keep in place.
Lube up your seals before putting them back down the shaft.
My conclusions on cause and repair of this known problem:
TMC uses this xcase for several models, so there are 3 actuator shaft holes in the case. (I have the AWD 2004 V8, so 2 shafts) The open hole in the case is allowing splashed oil to migrate towards the o-ring seal, once it gets to the o-ring, it is trapped in the gap between the plastic disk covering the o-ring and shaft seals and has no way to drain back into the xcase. Eventually when the o-ring fails the dripping begins, and every time the truck moves, that cavity is refilled with a small amount of oil. This is why it is such a small leak.
The oring design is also a failure in its own right. The gap is wide enough to put 2 orings in comfortably. So that's what I did on round 3. These orings by the way ended up being common ASA sized o-ring and can be had for pennies, it was size 035?, but I misplaced the package, but the Toyota ones are cheap enough to get 2.
The shaft seals are really not the culprit in this case, I had maybe 3 drops of gear oil visible inside the actuator on a 13 yo truck.
The key i think is to plug that unused hole in the case. It is slightly smaller than the stated seal ID of 15MM. Harwall sells blind 15mm seals similar to the old freeze plugs, and I drove 1 down into the unused hole. Not a drip in the 3 weeks since.
Was not able to get the old shaft seals out, so I bit the bullet and disassembled the actuator. Don't do it unless you mark the exact large gear positions, and the blue and white wheel positions, along with noting the exact enagement of the teeth on the shafts relative to the metal spur gears that engage them. There were lots of pictures and questions about retiming these, but no way to be sure they didn't all ready move something or mention reliably what setting the shift rods were in when dissembled.(4HI, 4LO, Locked/Unlocked)
I am now leak free, but will have to do further work on the diff lock setting, The blue pot is giving be an intermittent reading causing the flashing lock light issue. With that not working, it wont let you actuate the high/low mode.
This 800-1200 problem is fixed with 2 seals, 2 orings and 2 quarts of oil, and your time and skill.
