Flemster's 2000 SR5 Sport
@Fishwerks, if it doesn't make noise you have no credibility in my opinion. Thats how I justify all the noises mine makes.... :sad:
Thanks for the kind words in regards to the video!
MOAB PREP
More stuff that I've done recently.
-Valve Cover Gaskets - Replaced with OEM Gaskets from the Dealership - $40 a piece -_- (I get an employee discount though :lookout:)
-Spark Plugs - Denso OEM PN#K16TR11
-NGK Wire Set - TE66
I resorted to @Jon's write up
Valve Cover Gasket Replacement
All done at 200,xxx miles - Also changed Oil
Thanks to [MENTION=107971]derpiful[/MENTION] for the help on this one. Ran into all sorts of little annoying problems.
PICS
Did not take many pictures as we were chasing the sun and the cold.
script>
Old plugs were only 2 years old so they looked fine
script>
Upper and Center Manifold looked awesome! The oil is from my fingers :clap2:
script>
Mine were BAD. We also found out that every single bolt on my Valve covers were finger tight. It also has never been removed by anybody... This is the first time its come off.... Nice Toyota. So the seal may have been fine but it was never tight enough. It's been leaking as long as I can remember as well.
script>
Insides looked awesome, It was really hard to keep all the dirt and crap out, did the best we could... Thats why we have an oil filter....
script>
All back together, took about 2-1/2 hours. Which really isn't terrible for how many bolts come out, torquing things to spec, cleaning, chatting, etc.
script>
That is good time on the valve cover gasket replacements. I did mine about 100k ago and noticed just a bit of seepage around them. I thought I'd try tightening them and a few of them were so loose I could tighten them by hand. Unfortunately you can't reach the inside ones because of the intake and throttle body, but those might not be as loose as the outer ones I'm thinking since they aren't close to the exhaust manifold. I think the rubber on those grommet washer things dry out and shrink, and then the bolts aren't tight anymore.
New suspension looks good too!
That's a solid point about the washers shrinking. Mine were equally all loose all the way around. You may want to spend the 30 minutes to get into those. The manifolds were the easy part of the job. Weaseling the Valve covers out was a PITA because we couldn't figure out how to get those damn Fuel Injector wires out of the way. Ending up shattering all the plastic on the cover for one of them.
More Crap!
Installed the new rack. Looks so much better. I'm running it bare aluminum while in Moab to grab some attention and because I think it looks kinda cool. Probably going to paint it black again though.
script>
script>
script>
Also changed my Fuel filter... Real pain in the ass being mine was destroyed somehow. I've never noticed it for some odd reason, out of sight out of mind idk. But the fuel line was smashed!! I wish I grabbed a picture before tearing it apart but I did not. Here the piece of line I cut out.
script>
Had to buy a new fitting for the filter end, then used some high pressure hose to run about 4 inches of missing line, a few hose clamps and its good as new! Drove around for about 30 minutes afterwards and no leaks! Seems to be running a lot better but I wont really know till I take in the highway and test the mpg.
script>
Put a little teflon tape on the threads and installed it all.
script>
Stuff I still have to do...
Find / fix ticking noise
Exhaust leak
Install SPC Uppers, they are in the mail from the Group Buy on here.
Tap Skid bolts
Allignment
Easy enough
GO TO MOAB!!!!
TAP EATER
Finally got around to drilling and taping the holes in for the skid plate. My 60 some odd pound skid plate was held on by 3 bolts out of the 8 it allows. So [MENTION=107971]derpiful[/MENTION] and I drilled an tapped all the M8 holes to a 3/8's Thread. Pretty Beefy bolts holding it on now.
We managed to break two taps.Basically it would be taping really well, tap a little, back it out, tap a little back it out. Blah blah. By the book. No resistance. SNAP. The second one didn't even so much snap it kinda just exploded. So my truck has two taps forever inside it because screw drilling those out!
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40674567211/" title="Untitled"><img src="https://farm5.staticflickr.com/4622/40674567211_dca91afe8c_b.jpg" width="768" height="1024" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40632787312/in/photostream/" title="Untitled"><img src="https://farm5.staticflickr.com/4714/40632787312_89b29f61ae_b.jpg" width="768" height="1024" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Last piece of the puzzle before heading out to Utah. Sitting at 1" of lift up front and aligned. Still have control arms in the mail so I'll be doing it all again soon.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/26839394718/in/dateposted/" title="Untitled"><img src="https://farm5.staticflickr.com/4785/26839394718_a883890de2_b.jpg" width="576" height="1024" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Utah Spring Break 2018
UTAH!
Moab, UT
DAY 1
This trip is one for the books as with every Utah trip for me. Solid week of just wreaking havoc on my truck as usual. I'm going to go by days sorta since I took over 3000 photos in a week and there is a LOT I like. YAY ME!
Day 1 was Saturday the 11th of March.
Woke up early as piss and left straight for Moab from my Parents house in Conifer where I picked up my Copilot for the trip, Chai. She is a mut, german, rotty, blue healer, kelpy, etc mix.
Stopped for our first break inside Glenwood Canyon to walk the pup and letter get some wuuuter.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40184814624/" title="530A2226"><img src="https://farm1.staticflickr.com/791/40184814624_69c80f9010_b.jpg" width="819" height="1024" alt="530A2226"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Gas in Glenwood and again in Fruita. Averaged about 15mpg and couldn't hold 75 so I was cruising 70 most of the way and trying hard. Something was wrong but I just blamed it on the tent/wind and all the weight..... -_-
Stopped on 128 for few photos of the LaSal's in all their glory.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39999071255/in/photostream/" title="530A2230"><img src="https://farm1.staticflickr.com/800/39999071255_603240f6de_b.jpg" width="819" height="1024" alt="530A2230"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
On the way into town I had a lot of time to kill since everyone I was meeting with was on Metal Masher and had just gotten started around the time I was getting into town. SOOO I went out to one of my go to spots that never has people and I've camped at every time I'm in Utah except this time... But I got lunch and a nice walk with the pup this time around.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/26020436777/in/photostream/" title="530A2242"><img src="https://farm5.staticflickr.com/4788/26020436777_0e3f8aacd4_b.jpg" width="1024" height="576" alt="530A2242"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
I rolled into town, hung out at the park at 128 and 191 for about an hour an half after getting gas and groceries and just waited for the dudes to finish Metal Masher.
We all met up at Milts for shakes and then headed to camp.
I camped with [MENTION=78892]Fishwerks[/MENTION] [MENTION=107971]derpiful[/MENTION] [MENTION=94888]EatonKyleH[/MENTION] [MENTION=82211]TCMach[/MENTION] and a few others some left the next morning after already being in town a couple days.
Heres camp
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/26020403057/in/photostream/" title="530A2252"><img src="https://farm1.staticflickr.com/822/26020403057_a2350e6e46_b.jpg" width="1024" height="576" alt="530A2252"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/27022193458/in/photostream/" title="530A2251"><img src="https://farm5.staticflickr.com/4786/27022193458_6d84b3e840_b.jpg" width="1024" height="576" alt="530A2251"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
[MENTION=94888]EatonKyleH[/MENTION] gorgeous rig
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/26020416807/in/photostream/" title="530A2250"><img src="https://farm5.staticflickr.com/4771/26020416807_40f775b8ce_b.jpg" width="683" height="1024" alt="530A2250"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Beautiful night, good times around the fire and ready for trails in the morning.
To be continued...
Day 2
UTAH
MOAB,UT
Day 2
Poison Spider
We ran Poison Spider today with [MENTION=78892]Fishwerks[/MENTION] [MENTION=107971]derpiful[/MENTION] [MENTION=82211]TCMach[/MENTION] and [MENTION=121903]Black798[/MENTION] who we met up with in town. As well as few other friends of friends.
My mysterious ticking noise (Cracked Flex Plate, I assume) had gotten much worse after driving all the way from Denver and 4 low didn't help it at all.
[MENTION=78892]Fishwerks[/MENTION] working up the first obstacle with everyone in awe of that white power!
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/27022166038/" title="530A2286"><img src="https://farm5.staticflickr.com/4771/27022166038_55053c8262_b.jpg" width="1024" height="576" alt="530A2286"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/26020356377/in/photostream/" title="530A2288"><img src="https://farm1.staticflickr.com/807/26020356377_cccf11b878_b.jpg" width="1024" height="576" alt="530A2288"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
[MENTION=107971]derpiful[/MENTION] trying his hand at the "hard line" with the 35's... no dice.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/27022157018/in/photostream/" title="530A2301"><img src="https://farm1.staticflickr.com/795/27022157018_1667f800a1_b.jpg" width="1024" height="576" alt="530A2301"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
[MENTION=121903]Black798[/MENTION] coming up
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/26020345127/in/photostream/" title="530A2303"><img src="https://farm1.staticflickr.com/815/26020345127_6da179d1d3_b.jpg" width="1024" height="576" alt="530A2303"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Dougs gorgeous LS1 Swapped fj60 that is fully restored down to the frame.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/27022130518/in/photostream/" title="530A2322"><img src="https://farm1.staticflickr.com/801/27022130518_652f962c97_b.jpg" width="1024" height="576" alt="530A2322"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
[MENTION=82211]TCMach[/MENTION] trying the hardline. The holes that sucked everyone in was even eating up those 37's
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/26020320707/in/photostream/" title="530A2351"><img src="https://farm5.staticflickr.com/4783/26020320707_fe8f680e68_b.jpg" width="1024" height="683" alt="530A2351"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Chris getting Flaxy
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39998930665/in/photostream/" title="530A2358"><img src="https://farm1.staticflickr.com/785/39998930665_23a8d1374f_b.jpg" width="819" height="1024" alt="530A2358"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Hayden doing the same
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40850713942/in/photostream/" title="530A2374"><img src="https://farm1.staticflickr.com/803/40850713942_3702e5a201_b.jpg" width="1024" height="576" alt="530A2374"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Tylers truck is smexy
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40892514791/in/photostream/" title="530A2419"><img src="https://farm5.staticflickr.com/4786/40892514791_c5412395f8_b.jpg" width="819" height="1024" alt="530A2419"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
First noticeably "hard" ledge around the beginning. Chris walking up it.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39083230870/in/photostream/" title="530A2440"><img src="https://farm1.staticflickr.com/801/39083230870_8bfd32f859_b.jpg" width="1024" height="576" alt="530A2440"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Hayden going up next
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/27022075698/in/photostream/" title="530A2465"><img src="https://farm1.staticflickr.com/789/27022075698_a4f6eb2715_b.jpg" width="1024" height="683" alt="530A2465"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Phoenix going up
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40850679482/in/photostream/" title="530A2487"><img src="https://farm1.staticflickr.com/814/40850679482_32bd78d5c8_b.jpg" width="1024" height="683" alt="530A2487"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Tyler using them 37's making everything look easy.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/27022062248/in/photostream/" title="530A2512"><img src="https://farm1.staticflickr.com/820/27022062248_57a995e881_b.jpg" width="1024" height="683" alt="530A2512"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Posion Spider was like a slightly more difficult Hells Revenge which was awesome.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39998880315/in/photostream/" title="530A2547"><img src="https://farm1.staticflickr.com/809/39998880315_9267016623_b.jpg" width="1024" height="683" alt="530A2547"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/27022051888/in/photostream/" title="530A2562"><img src="https://farm5.staticflickr.com/4788/27022051888_b618597caa_b.jpg" width="1024" height="576" alt="530A2562"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40850653182/in/photostream/" title="530A2636"><img src="https://farm5.staticflickr.com/4774/40850653182_1675400008_b.jpg" width="1024" height="576" alt="530A2636"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Waterfall!
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40850646982/in/photostream/" title="530A2656"><img src="https://farm5.staticflickr.com/4785/40850646982_179d743d1b_b.jpg" width="819" height="1024" alt="530A2656"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40850635782/in/photostream/" title="530A2665"><img src="https://farm5.staticflickr.com/4773/40850635782_a0cf8bdc01_b.jpg" width="683" height="1024" alt="530A2665"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40850624032/in/photostream/" title="530A2674"><img src="https://farm1.staticflickr.com/815/40850624032_db309f9609_b.jpg" width="1024" height="576" alt="530A2674"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40850608912/" title="530A2698"><img src="https://farm1.staticflickr.com/800/40850608912_2671beb694_b.jpg" width="1024" height="683" alt="530A2698"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
To be continued....
Chris drives the most politically incorrect rig.
Excellent shots of the action, Flemster! I knew I was going to be jealous when you guys got back and started posting up your trip reports.
It's cool to see all the different 4Runners out using some recent upgrades. Half of those guys never update their builds these days.
Get the rest of the trip report up, I'm sure I'm not the only one who is curious what "something was wrong, but I blamed it on the wind" is all about.
As usual, killer job on the pictures Alex! I really need to step up my photo game soon and get a better lens. Can't wait to see the rest of the report
Time to start that Instagram account :ban:
3000 photos and here I thought I took a lot of photos. :wow:
Yes.... I take a lot! Filled 2 64gb cards with Raw files and another with video stuffs.
The mystery is mine to keep heheh.... no Ill update soon. Let's just say I'm leaving it at Toyota on Wednesday and I try and do everything on it myself and its only had a paid mechanic work on it once in my ownership and that was a week after I bought it for a timing belt job. Other than oil changes because I get them on the cheap at work.
Yes some of those rigs need more smexy photos posted on here.... Cough [MENTION=82211]TCMach[/MENTION] cough [MENTION=94888]EatonKyleH[/MENTION] cough [MENTION=78892]Fishwerks[/MENTION]
I'll be knocking them out piece by piece when I'm not paying attention in class.. :heh:
Thanks man! Honestly, it has been such a frustrating process but I'm finally getting to a point where I'm happy with my final product after 10 years of playing with cameras and I'm still not content. Yes, the gear does help but I try and stop and think more when taking photos to get the best angle and framing etc. (Which I still kinda suck at) as well as spending hours on hours editing to get them how I like them. No sleep life.
Thanks for sharing your pictures! I'm really bummed I wasn't able to make this years trip, but there's always next year. :thumb:
Please don't come because I'll be to busy gawking at your SAS and gorgeous truck to be sociable and have any fun LMAO.
But yes please do, if I make it again. This was a first for me with this crew in Moab, hopefully not the last!
Plus it would be fun to actually wheel with you and not just hang around a fire like the Jambo a while back.
End of day 2
UTAH
MOAB,UT
Day 2 Continued
Poison Spider
One of my favorites of Hayden following Chris up a steeper section before the V-Notch.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39083120870/in/dateposted/" title="530A2708"><img src="https://farm5.staticflickr.com/4786/39083120870_5e33ba5ebd_b.jpg" width="1024" height="576" alt="530A2708"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Hayden on the V-Notch
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39998810345/in/photostream/" title="530A2750"><img src="https://farm1.staticflickr.com/787/39998810345_b0a351b205_b.jpg" width="683" height="1024" alt="530A2750"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
My turn! This obstacle is honestly cake. Anyone could do it if you understand physics and have common sense. Enough said. Hyped up for what it actually is.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39083080140/in/photostream/" title="530A2779"><img src="https://farm5.staticflickr.com/4771/39083080140_458de57eea_b.jpg" width="1024" height="683" alt="530A2779"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Phoenix going up
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39998775855/in/photostream/" title="530A2782"><img src="https://farm1.staticflickr.com/784/39998775855_6fdb232ddf_b.jpg" width="1024" height="576" alt="530A2782"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Tyler eating it up
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39083052710/in/photostream/" title="530A2828"><img src="https://farm1.staticflickr.com/792/39083052710_e151a04961_b.jpg" width="1024" height="683" alt="530A2828"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Chris letting er rip on "High Speed Mesa" gotta send it!
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40184576274/in/photostream/" title="530A2868"><img src="https://farm1.staticflickr.com/818/40184576274_5b4bafcb52_b.jpg" width="1024" height="576" alt="530A2868"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Glamour shot of the ugly girl.
(Side note.... My passenger fender flare actually blew off on I-25 and then got ran over by a semi.... so that is why I'm running no flares.... -_-)
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39083028740/in/photostream/" title="530A2877"><img src="https://farm1.staticflickr.com/797/39083028740_21148c5a59_b.jpg" width="1024" height="683" alt="530A2877"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Forcing Hayden to do things he doesn't want to because peer pressure is cool.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40850495322/in/photostream/" title="530A2956"><img src="https://farm1.staticflickr.com/796/40850495322_f21ba07613_b.jpg" width="1024" height="683" alt="530A2956"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Looking like a fun little go cart
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39082992990/in/photostream/" title="530A2965"><img src="https://farm5.staticflickr.com/4782/39082992990_ae3f311852_b.jpg" width="819" height="1024" alt="530A2965"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
All Smiles out here
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39082982250/in/photostream/" title="530A2981"><img src="https://farm1.staticflickr.com/810/39082982250_75b7d7a375_b.jpg" width="1024" height="576" alt="530A2981"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
BOOOTAY ELERT
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/40892290151/in/photostream/" title="530A3028"><img src="https://farm5.staticflickr.com/4771/40892290151_f9cfb07bac_b.jpg" width="1024" height="683" alt="530A3028"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
So basically there is the final fun loop on Poison Spider that is optional, then you run everything again on your way out, we kinda just cruised through it all and I enjoyed it more than took pictures so I don't have much at all from that except from whats above that I liked sooo. We then proceeded to go to Milts for the second day in a row because it's yummy. Headed back to camp and I had to pull over and snag these because damn... Utah you purrrdy.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39082954760/in/photostream/" title="530A3092"><img src="https://farm1.staticflickr.com/812/39082954760_316f77f010_b.jpg" width="1024" height="683" alt="530A3092"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39998669025/in/photostream/" title="530A3095"><img src="https://farm1.staticflickr.com/788/39998669025_6e8aa7529a_b.jpg" width="1024" height="683" alt="530A3095"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39082945280/in/photostream/" title="530A3103"><img src="https://farm1.staticflickr.com/809/39082945280_e06409b33d_b.jpg" width="1024" height="683" alt="530A3103"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Set up shop with the remaning few for a wonderful night of fire shenanigans and some socializationizing.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/39082917410/in/photostream/" title="530A3114"><img src="https://farm1.staticflickr.com/820/39082917410_84c53c2802_b.jpg" width="683" height="1024" alt="530A3114"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
MORE TO COME!!!!
Loving the rig without the giant decal on the side.
You guys and your Moab photos make all the 3rd gen owners jealous. Great work.
mek
