Formidable 2002 Thundercloud Sport TRD Supercharged Version 2.0
Looking good! Love the color matched rear bumper.
Stoked to see more info on those LCA's. I still wonder if you will incur more rub on the underside of the battery box at full compression with a 315 tire. This has been my reasoning for not getting them so far but I would like to see some proof that this isn't the case!
Just waiting on the installer to get back to me with a date and time. Will keep you guys posted. Rubs right now with present wheel/tire setup.
Stainless water can, Wavian NATO fuel can mounted.
Black TRD battery stay arrived.
Technically it’s still lit!
I believe it’s required in all 50 states. This is better than running just the center plate alone. Will think of something. The rear end is not quite done yet. Exhaust will be rerouted, and a stainless dimple die plate will span the frame rails as is seen on some JDM builds. This will house a pair of flush rigid 3” back up lights that have been sitting on the shelf.
There's the can! What a rear end. Do they require you to light up your license plate in WA?
Can confirm you will rub the battery tray at full bump with a 315 tire. Not terrible but you do.
Wheel specs: 17x8.5 -10mm
Tires: 315/70/17 Cooper STT Pro
