Going Bigger - 5th Gen Tire Fitment Guide
This will sound like an unhelpful answer but honestly you'll have to try it to find out...each truck is different. You may have no rubbing, have to remove the mud flaps/do fender liner mod or although very unlikely get a BMC. It really varies that much with each individual vehicle.
Thanks. I'll order it and see what happens. I'll post some pics as soon as i get it installed.
I'm guessing but the most you will likely have to do is remove the mudflaps and put a heat gun on the fender liner. Good luck, it should look good, can't wait to see the pics!
Ya know... I never even thought of a heat gun approach and forming the plastic. It's the Neanderthal in me that immediately goes to cutting. But that's genius to just shape and mold as I please with a heat gun. +1
2016 le
Definitely different for every vehicle. I assumed I was in the "safe" zone with 20 x 9 (-12) Black Rhino Sidewinders with 275/55 R 20 Tires and I have slight rubbing (barely) on front and decent rubbing (Last 20% of stroke) on rear mud flap. Rubbing both when moving forward but also quite a bit in reverse.
Thanks for this. I have took some Nitto TG off my Chevy with stock 20's and was hoping i could put them on my limited. Looks like i can!
This thread is intended to be a reference point for all of you that are looking to change tire size. First here are a few links to get you on the right path:
Tire Rack - Your performance experts for tires and wheels This link will help with selection of tires.
Tire Size Calculator - Compare Tire Sizes This link will confirm below chart data.
Wheel Backspace & Offset - Truck Wheel Sizes - Truckin' Magazine This article will help you understand the concept of wheel offset and backspacing.
HubGarage.com - Custom Wheel Offset Chart Photos This is a chart on offset and backspacing.
I have included known data regarding our 5th Gen OEM wheels in the table below. Have fun and happy hunting!
***UPDATE*** Added OEM TE wheel backspacing information
HAS ANYONE HAD ANY TROUBLE WITH MOUNTING 275/55/20 ON THE 7IN STOCK WHEELS?
I tried to have Discount tire put Nitto's on and they would not do it. Said all 275/55/20 wheels are made for 7.5-9.0 inch wheels. Stock 20 inch wheels are 7 inches. Please help me clarify.
you just need to find a shop that is willing. they should be fine to mount, but if smethign happens, warranty will not be covering you.
Any idea to what it could mess up? I have a 2011 4Runner Limited AWD
it shouldnt mess up anything (i also have a limited, but havent swapped the tires out.. yet). that said, i imagine if you took a corner really hard there is a possibility of things going wrong with an undersized wheel.
Just installed Kumho 275/70/17 on stock wheels 17*7 with 15 mm offset , no mods , no rubbing, no lifts.
Sent from my XT1585 using Tapatalk
Do you have any side profile shots? I was looking for some pics of that tire specifically in that size on a stock suspension
No problems here. No rubbing either. I ran that size of Toyo AT2 on my 2013 LE then changed to my 2015 LE and made it to 50k without issue. I could have have 10k or more to. There has been a little round of the edge but that probably has a little to do with going on the narrower side of the recommended rim width. And maybe my driving (mostly city).
Now that I have a little more clearance with the x-reas traded out for Icon Stage 2, I'm going to see about fitting some 275/65/20 so I can get E rated tires.
Any one running General Grabber AT2s, 33X12.50R17LT? I'm guessing a 3 inch lift/level, but I'm not sure about mud flaps, liner etc...
I know tire fitment has been beaten like a dead horse here and in several other stray threads. I've got a 2016 TEP and a new Icon system (including tubular UCAs) on the way but I'm planning on getting some new shoes as well. I'm planning on 285/70/17 KO2s. Think I'll be able to drive away from the tire shop with little to no rubbing if I move the fender liner forward or should I wait until after I install the suspension/UCAs?
Also FYI Discount Tire has a labor day sale for anyone else looking at getting new tires.
Curious if anyone has ever used Kumho Road Venture AT51's on their 5th gen. Looking to get 275/70/17s on a stock 2016 Trail and found them pretty cheap on TireRack. They're rated/reviewed higher than the KO2s, only $632 for a set after an $80 rebate. Anyone?
I live on Long Island, and my T4R will mainly just be used for road, snow, and deep soft dead sand. In my experience, sometimes a properly deflated highway tire with softer sidewalks handles sand better than a hard-treaded knobby All Terrain. I suppose a C-class A/T would be a happy medium?
I put them on mine a week later I bought 2016 4runner trail, no issues , love them, good value.
dont know how to insert pics here i u need , i can email u
It's almost time for new tires and I started thinking about maybe changing sizes so I was wondering about the options. Then I came across this thread and studied the chart, read the posts, and now I don't have any questions!
So thanks for all the inputs guys! (and possibly ladies)
18x9 with 285/65/18 bf Goodrich ko2 tiny bit if rub.
275/60r20
I have a Daystar 2.5" lift on my 2016 Limited, would 275/60R20's fit without rubbing? The rims are 20x10 with a -24mm offset.
Sup SL.UG, it's tcr_89 creepin
Instagram @tcr_89 2016 SR5P 4wd 3rd row - FN wheels countersteer X - 265 KO2 - OME 2895E rear coils + Bilstein 5100 (1.75 setting) - NFab side steps - TRS Morimoto 4300k HID - NOKYA yellow fogs & DRLs - AVS hood visor
delislerebecca
