Help moving USB from center stack to glove box
7) ... You will probably have to undo one of the cable retaining clips to get enough slack to pull into the glove box. Said clip will become obvious while doing this, and it is easy to access and undo.
Just moved my USB port. This was the most important/ handy bit of information. Forgot about this step and was getting rather frustrated till I read this post, again.
Wouldn't it be easier to use NanoUsb memory? If stolen you are only out $10. NanoUsb is also small and out of the way.
I think I agree, if I understand what you mean. Are those of you wanting to move the USB port doing so to semi-permanently plug in an MP3 player? If so, why not just load your music onto a small USB drive? No power required and no need to move the port.
Well, in my case, I use a 160GB iPod, I'm not sure there are small USB drives with that kind of capacity. Plus, I like the iPod integration in the new T4Rs.
Bart
Bart
That makes sense. My USB drive is 128GB and I know you can get them up to 1TB now, although they are expensive. It's the "no battery required" that makes the difference for me but to each his own.
This NanoUSB is new to me.
I'm wanting to keep the music source in the glovebox. I'd prefer to keep the visible areas as free of wires as possible. Random wires stress me out. Not really, they just mess with my OCD. I already have iPods, it seems like it makes just as much sense to leave an iPod in the glove box and move the USB port. Which is what I did. Bluetooth would be good, but my connection seems to be kind of shitty and inconsistent when first starting up my 4Runner. Not sure if it's phone/ iPod, or stereo software.
So tell me this, how does the T4R use and display the data on a USB memory stick? Does it act just like an iPod full of songs? Or is functionality more rudimentary? I would definitely rather have a battery-less USB drive or something full of MP3s, and I would even spend the money on a 500GB stick if it would work with the audio system in the 4Runner the same way my iPod does. I guess I will have to load up some MP3s on a memory stick and see how it behaves.
Bart
Yup, makes perfect sense to me. The only snag is if leaving it out in the cold zaps the battery enough that the powered USB port in the 4Runner isn't enough to get it going again.
Bart
Bart
Yes, it looks pretty much just like an iPod. You can browse, sort by artist, song or album, set up playlists, whatever....
A "normal" USB drive will make the little rubber cover stick up which will upset the OCD types so I'm using one of these: http://www.amazon.com/SanDisk-Ultra...F8&qid=1451874664&sr=8-12&keywords=nano+drive
Hmmm, that is cool. PNY makes a 250GB USB memory stick. It's $150 but it would hold even more than my iPod. This is tempting...
Bart
Just read this thread after taking possession of my new 2016 Trail Premium today. I was definitely disappointed with the lack of USB under the center console arm rest or in the glove box.
[MENTION=123879]Trails4[/MENTION], are you saying no splicing is required at all? That there is enough slack to go into the glove box with the cable as is from the factory?
Thanks - Bart
That's correct, I was able to unclip the cable from the console and run it back to the glove box port without any need for splicing, removing tape, etc. "Hardest" part was safely removing the console panels without scratching them, all else was easy.
Yeah, I actually went ahead did this last week, super easy. Did it in the parking lot at work.
Bart
Question, will it hold album art doing it this way?
If you dont mind explaining how you did the file system. Similar to Itunes...Artist folder, album folder inside artist, songs inside album folder. So songs would actually be two folders deep?
Thanks in advance
Yes, it holds album art. I didn't overthink it; just plugged the USB drive into my PC, dragged a bunch of music onto it and then plugged it into the T4R.
Wait a minute!!!
Am I seeing a mod that AntMan and sp8ball did not actually do and document???:gossip:
Um don't us 10-13 owners have no need since it was already there? You also got hosed on the outlet in the center console!
Oh any you don't have a party mode either! :bounce:
Wait, the earlier ones have an outlet under the center arm rest? Feckers!
Bart
Ambrose67
