j0mama said:Well I am using a external amplifier, and couldnt be happier.... but that was a REALLY old post... but I give him credit for trying!
j0.
mhumm2 said:Sorry about that, but like you wrote, I tried. Anyway, I noticed in your signature block, "(Orange)" after Camry Navigation. Is that because your head unit has orange colored lights and matches the rest of the interior lights? If so, how did you change the lights to orange? Thanks.
Mark
mhumm2 said:Well I just received my nav unit and plan to install it this weekend, but where is the map DVD? I hope OEMValue already loaded it in the unit, because it was not in the box.
For those of you that purchased systems from OEMValue, where was the DVD? Thanks
Mark Hummel
mhumm2 said:Thanks for the informatiom Spyderdoc, I appreciate it.
Petegaz, here's a quote from your nav install web site:
"Next you will need to tap into the Reverse Sensor. I found the best spot was on the passenger side of the vehicle in the kickpanel (just to the right of the pollen filter). You will need to remove the glove box"
My challenge is that I don't know where the pollen filter is nor do I know where to look once I remove the glove box. Would someone please describe exactly where the correct kickpanel is that's referred to in the quote above? I'd like to be able to go to the correct kickpanel on the first try if possible. Once I remove the panel, I'm sure I'll be able to confirm it's correct and find the right wire to tap into thanks to Petegaz's close-up photo.
As far as the GPS antenna location; I was thinking about mounting it flush with the dashboard, in the center immediately in front of the defrost vents. I'd even be willing to cut a small (custom fit) hole that matches the antenna itself then seal it with a little Silicon RTV. I've used a Garmin GPS on the boat and learned that keeping the antenna flat, meaning parallel with the ground, and not obstructing it's line of sight to as much of the sky as possible is the best way to lock in as many satelites as possible. That's why I don't like behind the rear-view mirror location very much; I think it's too limiting.
Another option I'm considering is an external mount next to the moon roof using RTV adhisive and a small piece of metal RTV'd in place to protect the antenna wire. Vandalism would be a small concern, but locking in every satelite possible would be easy as the antenna would be able to "see" at least twice as much sky as it would inside. I already have my XM radio satellite antenna on on side of the moon roof and a different GPS antenna on the other side. Of course that GPS system is going to be replaced with the Camry nav system, but it's able to routinely lock in 8 to 10 satelites without a problem and I get extrememly accurate tracking. It's even able to place my vehicle in my driveway and on the correct side!
Comments are invited, please and where is that kickpanel for the reverse wire? Thanks.
Mark Hummel
mhumm2 said:Hello:
As many of you know, I received my 05 Camry Nav system from OEM Value. I also ordered the microphone system that plugs into it. As I understand it, there are several voice commands, I can use, to control the nav system (and I don't just mean changing modes [AM/FM/Nav etc]).
Does anyone have a complete list of commands that the system recognizes?
I believe there is a pdf of the commands posted at Siennaclub.org. Try doing a search over there.
Please advise.
Mark Hummel
petegaz said:To All:
I recently installed the Toyota Navigation system from oemvalue.com in my 2003 4Runner Sport. There were a few issues I had in getting the system to work 100% (speed & reverse sensor, antenna amplifier).
spyderdoc said:Do a search. There is a very long thread about the exact procedure and which LED lights to purchase. Remember, it is a HUGE PITA to do......20 something tiny little surface LED's to remove and replace. You need a good steady hand so you don't do damage with the soldering iron....
Good luck
Mark
gregtay said:... and this weekend i FINALLY converted my Solara nav over to OrangeTook most of my Saturday, but it was worth it. The LEDs are a perfect match to the rest of the dash lights.
spyderdoc said:What a difference, huh? A huge PITA and very risky, but was very much worth it!
Mark
mav75 said:I am drooling for the navigation system, but I'd probably start an electrical fire trying to install it. Do you think a Toyota dealer would do it? If not, what about a car stereo shop? For money, they probably would.
Also, what kind of warranty does oemvalue.com offer? Is this original fresh out of the box or refurbished equipment? Where could you get tech support?
The install is seriously easy. The hardest part was tapping into the speed and reverse sensors...but one reason that was so hard is that the instructions in this thread say that the wires are 24 guage. I don't think they are any smaller than 22 guage, and may even be 20 guage. Anyway, I could not tap them with a connector designed for 22-26 guage, and had not problem tapping them with an 18-22 guage connector.
