Hilux 167 snorkel for 3rd gens
Ordered mine last Friday and got it today...now to actually decide if I want to drill a giant hole in my fender...
You lucky MOFO.
I ordered mine the 7th and it's not supposed to get here until 3-21APR......
EDIT****************
SHOULD HAVE IT TODAY!!!!!!!
Friday, March 13, 2015 6:25 AM, Jacksonville NC US Out for delivery
Friday, March 13, 2015 6:22 AM, Jacksonville NC US Package arrived at a carrier facility
Friday, March 13, 2015 4:51 AM, Goldsboro NC US Package has left the carrier facility
Friday, March 13, 2015 4:35 AM, Goldsboro NC US Package arrived at a carrier facility
Friday, March 13, 2015 3:26 AM, Raleigh NC US Package has left the carrier facility
Friday, March 13, 2015 1:36 AM, Raleigh NC US Package arrived at a carrier facility
Friday, March 13, 2015 12:05 AM, Greensboro NC US Package has left the carrier facility
Thursday, March 12, 2015 9:11 PM, Greensboro NC US Package arrived at a carrier facility
Tuesday, March 10, 2015 1:01 AM, Baldwin Park CA US Package has left the carrier facility
Monday, March 9, 2015 10:09 PM, Baldwin Park CA US Package received by carrier
Sunday, March 8, 2015 11:13 PM, US Package has left seller facility and is in transit to carrier
Another tweak; after all your holes are cut/drilled for the body of the snorkel and ready for install, I installed the rubber "L" shape component on the snorkel so that you can get a nice tight seal with the steel clamp where plastic meets rubber. I then installed the snorkel feeding the rubber in first and through to the airbox area. Once there it took a little heat and application grease on the airbox intake to get the rubber end on the airbox. I had a mechanic friend of mine helping me at that point, as it is easier with an extra set of hands and do not forget to have the hose clamp around the rubber before attempting to install it on the airbox. I did it this way because of easy access to the hose clamps versus after being installed and then trying to get a good seal inside the fender tight against sheet metal. Hope this helps. Below is a drop box link for some pics of what I did, not sure how to upload photos as I'm a NEWBIE.
https://www.dropbox.com/sh/t3kvjk5uemkfeim/AADbtaEBstIIW6bq9vVO64DRa?dl=0
this is exactly what I had in mind... glad to hear it worked out that way
You lucky MOFO.
Ive got the best shipping track, this is crazy!!!! Half way around the world in less than 48 hrs!!
Las Vegas, NV, United States 02/18/2015 10:29 A.M. Delivered
02/18/2015 6:57 A.M. Out For Delivery
02/18/2015 6:11 A.M. Arrival Scan
Ontario, CA, United States 02/18/2015 1:56 A.M. Departure Scan
Ontario, CA, United States 02/17/2015 11:38 P.M. Import Scan
02/17/2015 10:37 P.M. Arrival Scan
Anchorage, AK, United States 02/17/2015 4:40 P.M. Departure Scan
02/17/2015 1:54 P.M. Arrival Scan
Shenzhen, China 02/17/2015 8:59 P.M. Departure Scan
02/17/2015 1:57 A.M. Arrival Scan
Sepang, Malaysia 02/16/2015 11:30 P.M. Departure Scan
02/16/2015 8:41 P.M. Export Scan
02/16/2015 8:15 P.M. Arrival Scan
Shah Alam, Malaysia 02/16/2015 8:00 P.M. Departure Scan
02/16/2015 7:29 P.M. Origin Scan
02/16/2015 4:14 P.M. Pickup Scan
Malaysia 02/16/2015 3:08 A.M. Order Processed: Ready for UPS <-------Malaysia Time the order was placed around 6:00PM the 16th PST.
If you take the whole mud shield out it is quite simple to get a seat on the snorkel from the rubber tube.
I attached it to the air box about halfway on the tube and then tightened it down so it wouldn't move while running it through the fender wall. With the mud shield out you can get enough hand up there to seat the opposite end and you also can easily tighten the hose clamp nice and tight.
**I did use a long screw driver to pry the end of the snorkel away form the fender so that its easier to slide on the rubber tube.**
Haha when I looked at the box I noticed that mine was sent from CA. I wonder if any of these are actually from overseas.
I ordered mine Feb 20. Arrived at my doorstep March 5, even though it said April 10-16 delivery. Pretty happy about that.
The installation was straight forward and went well. I just used an angle grinder to cut the hole in my fender haha. I couldn't be bothered to buy a 3 5/8" hole saw that I will never use again. The only thing worth mentioning was locating the 5 holes to drill. I just drilled two holes at a time, test fitting the snorkel each time to make sure the holes are lining up.
I'll try and get a picture up soon.
I am doing the same thing only I am choosing a slightly smaller tool instead. I think the Dremel will cut it out nicely.
Anyone else have a problem connecting the L shaped rubber piece to the snorkel itself? I've got it connected to the intake side but can't get the top corner closest to the fender to fold over!! Worked on just that part longer than the rest of the install. I don't believe I would be able to install it on the snorkel side first and then be able to connect it to the airbox. I had to quit for the night because I was frustrated. Everything else went smooth as silk and looks amazing. Anyone else have a check engine light after install?
Clean your maf and buy some prefilter at Napa and stuff it in the top. Shouldn't have a check engine light though.
I have yet to make the connection for my intake to the L rubber thing but I am waiting for tomorrow. It's too late.
Make sure your MAF is plugged in.
I used a long screw driver to pry the snorkel away from the inside of the fender and then was able slide it one. I had to make sure the other side wasn't too far on to the airbox, so that there was enough slack to accommodate the snorkel side.
Not bad for 109. Really nice. Well built.
Should've made my own stencil, but that's nothing for the price.
167
Did anyone else recieve hardware that looks like rivits? There are 6 of them. It looks like they would be for the bracket for the A-Arm. If these are not used, is everyone mounting that bracket with self-tapping screws? Pumped to get this thing on. Thanks to the OP and everyone that has commented.
I wouldn't even use self tapping that close to the windshield. I used vhb tape from 3m since the pressure is only vertical and not much for side to side. Simply clean both surfaces with alcohol and vhb will do the rest. Pretty amazing stuff.
Philthyphilthy
