Hilux 167 snorkel for 3rd gens
Just curious... about how long did it take everyone to do their install? Now if only this rain would let up... :rain:
As long as you need to. Honestly I took about 2 or 3 as well. But I went back and waterproofed everything for a final install a few weeks later. That took just as long.
Feedback from my install
Thought I'd give some feedback following my install which was the BIGGEST PITA.
First... I'm fairly mechanically inclined and this project took me WAY longer than I expected. I like to do most of my repairs myself, but make sure you give yourself plenty of time. I ran out of daylight and then it started raining on me :rain:.
• Do yourself a favor and buy some of the plugs they mentioned earlier for the mud shield. You'll need them.
• The 3 5/8 saw hole makes for a really tight fit. You'll likely need to clean the hole out a bit with a regular drill bit for a little more clearance.
• don't be shy about using a little bigger drill bit for the bolt holes. The washers from my amazon kit were huge and the little bigger bolt holes allowed me to maneuver the snorkel easier (and without damage to the threads of the bolts).
• I used a can of spray paint to paint the holes I had made... hopefully to provide a little rust protection. Doesn't have to be pretty... just have a rag handy to snag any drips... it'll all get covered by the snorkel anyways so no need to be perfect.
• For the snorkel attachment on the A-pillar... don't drill your holes for the A-pillar until the snorkel has been fully tightened down to the body of the vehicle. My holes came out about 1/8 of an inch off and the snorkel had to flex a bit to get it mounted. (And definitely use the rivets. For those that haven't used a riveter, keep pumping the riveter until the stem fully snaps off. This is how you know the rivets have secured fully to the sheet metal and snorkel bracket).
• I tried to install the rubber elbow onto the snorkel before feeding it through the fender and that didn't work for me. I had two hangers inside it which made it difficult for it to flex which resulted in having to install the rubber elbow inside the fender like everyone else.
• This was a helpful tip mentioned earlier: **use a long screw driver to pry the end of the snorkel away form the fender so that its easier to slide on the rubber tube.**
• For the rubber piece to the air box... use a little grease or motor oil to lube the end of the rubber. Vice grips on the bottom, a small screw driver, and a boat load of patience finally resulted in it seating properly. An extra set of hands would've helped tremendously, but unfortunately I didn't have that option (or a heat gun for that matter... tried the wife's blow dryer but not sure it helped much).
• Cheapest place to buy the tools was harbor freight for the mandrel ($10), Amazon ($10) for the hole saw and Home Depot for the Riveter ($10)
Thanks to everyone that's contributed to this thread! :beer:
Success! Got it all setup, looks great too. The biggest PITA was getting the L tube onto the snorkel itself, pushing the snorkel from the fender definitely helped it on there. I'll look at the the L tube again in a few weeks to make sure its on there tight still.
I'm hoping someone has some tools for my snorkel install...
tools needed:
- riveting tool with M5 adapter ( just like original post picture )
- a 3 5/8 hole saw to drill the BIG hole
Hi All,
I am interested in doing this mod. However, I installed Side Marker lights on the fender. Can someone please measure the distance from the lowest part of the antenna mount to the lowest part of the snorkel. As attached.
I do not have the paper template and would like to know if the snorkel will clear the side marker lights.
The pic is rendered from Zig553 post. Hope you do not mind me using as reference.
Thanks,
Rod
Hi All,
Thanks,
Rod
Hi, no problem about using my pic. Did you need a template? I still have it somewhere, I could probably just mail you mine.
Is there any gap between fender and snorkel?
There is a tiny gap in the crease of the body line, probably could be fixed with a little adjusting. I have since broke a lbj which collapsed the truck onto that fender as well as got friendly with trees so it's not the prettiest thing. I'll snag a pic if I can today
Sent from my SM-G530T using Tapatalk
Thank you, really appreciate you taking the time to take some pics!
I want one! Has anyone run the intake (top) backwards? It seems like it would catch a ton of branches forward like that. No one having that problem?
Sorry for the delay, I can fit about a quarter of my index nail between the body and snorkel
As for the post above, I turn the head around in heavy wet snow, I remember that with the head facing forward you'll get more air into the engine, but not a huge difference with n/a
http://uploads.tapatalk-cdn.com/20160413/43c9171bff96da6a96a1432b08c0ddac.jpg[/IMG
Sent from my SM-G530T using Tapatalk[/QUOTE]
No problem Thank you for sharing. Am thinking about it but make just end up with the tacoma instead!
Thanks for the write up!!!!
I installed mine last week.
For future reference I think the 5 pins are so you can rivet the windshield bracket onto the truck. That's what I did instead of the self tapping screws.
Got mine done today!
20160604_160524_zps7g6o63cv.jpg~original
Used 8AWG Bare Copper to correct the vacuum.
20160604_112517_zpsbtufmapr.jpg~original
This is how much the template is off.
20160604_121858_zps1dzhcsdq.jpg~original
Had to reinstall my Stock Intake. Used my K&N Tube for the ISR Mod.
20160604_150630_zpsjekooaxr.jpg~original
20160604_160407_zps8ydd9nvd.jpg~original
Getting to the last two posts are a PITA!!!! I used silicone to stick everything together so I could get it with just the tips of my fingers. After it was started then I could get a wrench on it.
I agree with Doc...great write up!
This really frustrates me...these guys can make this snorkel kit and sale it for a profit at $170 with free shipping! Then ARB makes a very similar snorkel...yet they sell theirs for over $400 plus shipping! Come on...why does ARB have to charge so much for their products??:shrug: I know it's quality stuff...but damn!!
It's $132.59 today.
This is a sweet write-up. One question about the cuts you made: Did you put anything on the exposed metal in order to prevent rust or anything? I'm thinking that dremeling it all smooth and adding a little bit of rustoleum or something to protect it.
That was my first thought. All of those holes have to be deburred, primed & painted or your fender will start rusting away.
Done, Done, and Done. I used some Por15 on all the holes, front and back. Also used rubber washers on the back side.
leolediola
