Homegrown Tune Up
another1
So they wanted $550 for a tuneup...running rough, and thought that was a good place to start.
$180 for parts...an hour or so for me to plug the stuff in.
New plugs, wires, rotor, cap, air filter.
Now it starts, then dies. Starts and runs if you press on the gas pedal and keep it flowing.
Checked the firing order and went over the wires 20 times.
I know it's vague, but any thoughts?
How can I tell?
It slipped in and only had two screws to secure it.
Thanks for the reply.
BTW, it's a '92 Runner I just bought and when I had it looked at the mechanics said it looked like the wires were original. Two plugs were pretty fouled, the other four were nasty.
Plug gap correct?
Air gap correct?
Vacuum leaks? (use a vac gauge and tie it into the intake mani tree and watch the readings).
Timing at 10 degrees BTDC (with those 2 terminals jumped with a piece of wire)?
Gas cap seating properly?
No crossed/touching/shorted plug wires? And heaven-for-bid you didn't use any Bosch stuff?
Check all those and report back............
