How man 3G'S have functioning A/C?
96 286,423 miles and a/c works great....I did have to replace the expansion valve at 223,500 miles and also the receiver drier since I had to crack the system open for the ev. Cleaned the evaporator core cause already in there for the ev replace.
IMG_7807.jpg~original
99 202,xxx or something miles a/c also works great, no work needed so far.
There's always a hovering threat for a snowstorm...
242k miles and never touched, as far as I can tell.
Little over 200k on mine,AC works fine. I usually just drive with the windows down but it's been so damn humid and/or rainy lately.
Pulled over and running during those 20 minutes? Sounds like a bad cooling fan clutch,also check for debris impeding airflow to the radiator.
I will do that thank you very much.... i'll keep you all posted.. is that an expensive item? I dont have the space or the tools to do a lot of major work... I also have a "overheating smell" so you might be on the money.
I am amazed that on his 99 he still has the factory stereo.
Clock here good too!
The stereo was one of the first things to go. 3- or 4 H/U's ago .. it was going to be a bench radio- power it up with a 12v supply- but it got thrown out by mistake... you know... you put something in a box that you dont mean to throw out... but you do anyhow...
I assume that is on recirculation - ?
407k and still blows 39~40* while idling on 100* days.
If so, have you measured the temp on normal ?
Curious.
As far as the OP's question , mine works - added a little R134 a year or so ago and cleaned the condenser a month or so ago.
It's OK , but nowhere as good as the one on the '94 Land Cruiser I had.
This summer all have had to work their coils off, including the house ...
Britt
Curious.
Britt
Yes that was in recirculate mode. If measured on normal, it's usually about 5-10 degrees warmer.
1998
I have a 98 with unknown miles, estimated oveer 300K. When I bought it, the air temp was around 80-82, evaced the system and recharged it. Now it blows COLD again.. I forgot the exact temp, but I know it was under 50.
The AC belt just broke on me at the beginning of summer (on the hottest day of the year, go figure) at 164k miles. Blew ice cold before the belt snapped. Will get around to replacing it eventually.
TL-DR... Replace your fan clutch with Aisin FCT-013 if your AC changes based on vehicle speed.
When I bought my '99 with ~245k miles a few months ago, temps were just starting to hit the mid 90s in CenTex. The first time I had it in stop and go traffic with the AC on, the temp gauge started rising.
$#!&, turn off AC, turn on heat full blast. This happened a few more times. Overheating when the engine was working hard at low speed going up hills.
During that time, the AC was mostly 'meh', and would be barely cool when stopped and idling.
Put in a new fan clutch and BAM, great cold AC, and solid steady engine temps even with the heat wave the last couple weeks of 100+ temps.
I guess the old fan clutch wasn't up to the task of moving enough air through all three layers:
Trans Cooler || AC Condenser || Radiator
I have a feeling that I'm going to end up going to the dealer when i go back for my inspection... as long as i'm moving the engine stays cool... pullover for 20 min and it starts to overheat. I'll keep everyone updated.
I'm just glad that all these AC's are still up and running!
It's not your AC, it's your fan clutch.
https://www.amazon.com/gp/product/B00829HBEE
That's the OEM manufacturer replacement.
It's a very easy job requiring just basic hand tools.
delislerebecca
