how to find outset wheels
ttudesperado
I have a toytec ultimate on my limited and put some 20x9 w BFG Rugged Terrains 275 60's on it, and was wanting something that stuck out more, the Level 8 strike 6 rim from discount tire stick out some but but i want a wide aggressive stance. Most of the rims have a 12mm offset and 4.5-4.75 back space. Do i need more offset or back space and any ideas where to get some?
Konig Countersteer X's have a negative 10 offset. You could always use spacers for some extra poke.
ya i had the spidertrax spacers on the factory rims and loved the stance. Discount tire wouldn't work on it with the spacers and i do alot of traveling and had a flat and discount tire almost didn't fix it because they didn't want to touch it w the wheel spacer, what specs would a rim have to out set it as much as the factory rim with spidertrax spacers
Look for something that's at least 9" wide if not 10" with an offset of -25 to -35.
Just remember:
Negative offsets mean your rim will stick out further from the center of your truck.
Positive offsets mean your rim will tuck closer towards the center of the truck.
This goes for any wheel from trucks to cars.
The stock LTD wheels are +15 with a 7" width and look like a sunken ship in the 4R's fenders.
I will have pics of a 9" -12 setup soon. Since you are lifted you may want to go with wheel specs that are much more aggressive, like i posted above, as my specs will fit under the stock fenders sans lift.
the specs are in the original post
