How to: Installing 3rd gen spark plugs
Do folks want this thread as a sticky?
  • Yes
    Votes: 10 62.5%
  • Good thread but the search function works fine, no sticky necessary.
    Votes: 6 37.5%
  • Total voters
    16
  • Poll closed .
So I am getting ready to do plugs on my new 2000 limited and bought the NGK's in this forum, but I have a question on the gapping. Is the gap on a double plug a summation of the two gaps? Or should I have .043 between each side? All 6 of the plugs I got are between .024 and .028. Do I bend them out?
If they are indeed gapped incorrectly take them back to where ever you purchased them. They should be pre gapped a lot closer than what you have.
So there should be a .043" gap between the tip and EACH electrode, not a .043" gap between the two electrodes? The guys at Advanced Auto Parts were not helpful and thought the gap the plug had should be the gap you use.
I guess my real question, after looking at single electrode spark plugs where you measure the gap as in the height from the tip to the electrode, is how do you measure gap on a double electrode plug. Which tool do you use?
Use a wire gap tool, not a flat feeler gauge type. The gap of .043 is where the spark jumps across to the center post, so .043 for each side, not additive. The spark doesn't jump all the way across, it jumps to the center post from either side.
Sorry, old plug I had lying around but hopefully this shows you must use a wire gauge on each side.
[MENTION=148400]tystaco[/MENTION], any way you can post a pic of your plug? I've never heard of a factory-gapped plug at .024.
I was just using a coin gap tool at the counter of the store, I will look for a wire gap today. I hit the other forums hard last night and saw a lot of the same... .02-.03, and a LOT of people saying you just leave them the way they are, which seems crazy since these were the factory plugs with a supposed set gap. I am wondering if the coin tool was getting caught between the two points of the arc on the electrode and essentially measuring a tangent between them and the side of the center point.
It's hard to tell by just looking, but those look about right. Just comparing to the ones I just installed in my 2002 Sport with 256K miles.
The job is done. Picked up a wire gauge at home depot...had gauges for .04 and .045...two plugs had a side that would allow the .045, so I slightly reduced those to easily clear .04 but not .045.
Everything went pretty smooth except the last two on the driver's side. The middle plug had the lower portion of the boot stuck on it...had to use hemo-clamps to pull it out so the spark plug wrench could get on the plug...and then the last is just a *****...luckily I have Donald Trump sized hands and managed.
My rig had been having issues with a hard start once hot...had to crank on it for 5 or so seconds. I replaced the fuel pump...no fix. I am thinking doing the plugs got it, but I haven't driven enough to fully test yet.
Thanks for all of the help!
These were the plugs that were in it...
i just swapped in new NGK plugs and followed the pre-gapped thought process...
i did check them with a flat gauge and was only getting .024 like above....didn't wan't to start messing with them, now i'm glad i didn't
i have a coin and flat gauges....guess i'll have to get a wire one
i'll pull the plugs when i get my new wires
Just Installed New Spark Plugs and Wires
So I just installed new NGK Plugs and wires. Everything went pretty smooth except I was worried about the color od the plugs I pulled. They all look to have white residue on them. Is this normal?!!
