InfamousRNR's 2002 Limited BU!LD THREAD
The only stickers I have now are on my window...
It's line-x bed liner. Permanent . Plasti dip is temporary
Did you ever have a problem with your grill-guard shaking when going over a bump of any sort? I tried to recreate the shaking when stopped but it is just simply secure. Did this happen to you?
"Grill guard"???
Like my bumper or the actual grill itself? I'm confused
Ultimate Yota Pismo Jamboree 2016. Pismo, CA.
Finally made an acrylic piece to hold my Scangauge II
It is basically a clear price of 1/8" plastic from tap plastics, 2 holes drilled through to secure to the radio surround in place of the ash tray & the scangauge II is secured to the plastic with 3M double sided tape.
Nice! How did you do the switch panel?
Super Swamper IROKS just weren't aggressive enough for the mall parking lots so I decided to switch it up to some tires that can really handle my mall crawling.
watch out christmas shoppers, I'm coming for you this holiday season
CV AXle reboot and installation
[MENTION=120071]mtbtim[/MENTION] and I have been doing some good work regarding the DIY videos for 3rd gens...
here is another one where we reboot my OEM cv's and install them.
<iframe width="560" height="315" src="https://www.youtube.com/embed/vcCT4UgFUTw" frameborder="0" allowfullscreen></iframe>
You need to convince Tim that buying a welder is a good idea. It could lead to many more videos.
Good luck with the boot extension. I am curious to how long it holds up.
Those tire are insane.
i solid setup with argon gas would run at least $2,200 used...
what would we be welding on a regular basis? and what kind of videos could we make if we had one?.....
Sliders, bumper, roof rack as projects. Just throwing out some ideas.
Keep the videos coming.
Knowing how to weld would be a huge plus. Something to aspire to.
We do have another video coming out soon. We replaced LCA bushings for another member last Sunday. We installed Whiteline poly bushings.
id be more then happy to house some video shoots if thats what you wanted to do! that would be fun! maybe i could getten a mac to do the editing on
Houston, we have a problem!
Last night I was driving home, heard a pop of sorts & pulled over..
I had to get towed home as my truck would not move in any gear... engine still runs fine just no movement in gear with a nasty metal grinding noise..
[MENTION=100687]Konkordmusk[/MENTION] had an idea it could be my flexplate, so I'll start there.where usually it's cracked making noise but If it's my transmission or transfer case I'll be a pretty bummed dude for a while..
Anyways.
