Installed Hella MicroDE fogs w/ new turn signal stalk
Nashvegas34
I am kicking myself for not having done this long long ago, but I finally installed new Hella MicroDE fog lights for my 2000 SR5. There has been a lot of discussion here on the internets about how easy/difficult this is and the extent of the wiring already present on the SR5. As many of you know, if you look under the bumper behind the fog light knockouts there is an open connector just waiting to fulfill its purpose in life.
I bought this light kit:
TOYOTA SR5 4RUNNER FOG/DRIVING LIGHTS HELLA LAMP KIT | eBay
It comes with the lights, bulbs, relay, switch, and wiring, plus instructions for mounting the lights and wiring the switch to the dash. I didn't really want a dash switch, though. I wanted the switch on the turn signal stalk, like it would have come from the motherland had it been so equipped, so I bought this:
Part Detail
Part number 84140-14120 for my 2000.
The instructions say to mount the lights, then wire the switch. I did it in reverse because I wanted to make sure the new turn signal stalk would operate the lights before dealing with the actual mounting and alignment (more on this in a bit).
Photo 1:
I started by taking off the panel beneath the steering column, held on by 4 10mm bolts. Make sure you have a 10mm socket. This just so happened to be the one I lost back in the day changing the mother-in-law's Buick headlight. Needlenose pliers worked here, but would not work in a later step. In the pic above, the panel is resting on the floor but still hanging by the hood and fuel door release cables, You can disconnect these to get the panel completely off, but not necessary. Then, remove 3 screws from the bottom half of the steering column cover. One screw is right below the steering wheel. The other two are behind the wheel, so turn the wheel to get to them. The top and bottom of the steering column cover are clipped together, so I had to push, pull, and squeeze to get them to separate. Also in the pic, there are two small Phillips screws holding the turn signal stalk in place, and a wiring harness plugged into the bottom of the stalk. On the harness, push in the clip and the harness pulls right out. On the stalk, remove the two screws and the stalk pulls right out. Slide the new stalk in and insert screws, insert the harness, then put the steering column cover and lower panel back on with the screws and bolts. I then confirmed that the new stalk worked the headlights and blinkers. I also went ahead and put the relay into the empty slot in the fuse box in the engine bay and plugged up one fog under the bumper and confirmed that it worked. This is literally all there is to the wiring if you're not doing the dash switch.
Photo 2:
I then went under the bumper and attached one of the mounting brackets. This is where I really needed the 10mm socket, so I made a trip to the neighbor's. Once the bracket is attached, space is really tight around the nuts, so have a small ratcheting wrench or driver available. The nuts are only slightly larger than the hole in the mounting bracket, so I added some washers (shown in photo 3 below) to make sure the old rusty nuts wouldn't break and slip through and cause disaster at 75mph.
Photo 3:
This is where it got fun. And by fun I mean complicated. And by complicated I mean :wtf: The light is attached to the bracket by a single bolt, although the attachment feels solid. This mounting bolt, along with the other bolts/screws marked in the photo, are all used to position and align the light with the hole. In fact, even the 2 10mm nuts holding the bracket to the bumper can be loosened to help with this. The tricky part is that the front of the light with the lens does not slide into the hole, it only rests against the back rim of the hole. This means all of the alignment screws have to be used to properly seat the light against the back of the hole. At one point I swore the light was existing in 4-dimensional space because every adjustment I made seemed to screw up another one. It would be helpful to have a friend with whom you're comfortable in close quarters hold the light steady while you adjust and tighten. Even then, though, I still had to make several adjustments by turning the lights on and seeing where they were aimed.
I rinsed and repeated photos 2 and 3 for the light on the other side.
The next photos are how my truck looked before and after:
The install was way easier than I expected for the part around the steering column and dash, and harder than I expected actually mounting the lights. Overall I am extremely happy with the result. Having the switch on the stalk is great. I did some driving on rural interstate earlier tonight after finishing and the lights make a huge difference. I'm not sure I can drive with just my low beams anymore. The fogs don't project as far out straight ahead as the high beams, but spread light low and way out wide, making it much easier to see things like deer or road debris at night. I'll probably check the mounting every couple of days for a while to make sure nothing is coming loose, but I think I have everything pretty tight.
I would definitely recommend this seller on eBay. The lights were packaged very well, with plenty of padding, and communication was excellent. He also included a pair of 2"x5" rectangular driving lights, along with a wiring kit, that I plan to use for rear-facing auxillary lights. Overall, very pleased.
Oh, and I will be coming up with something for a splash shield for these lights. As others have said, they are directly in front of (within 12" probably) the tire and would get blasted by water or whatever else the tire picks up off the road.
Very cool, I was hoping someone would fab some of those up.
I'd happily pay you for a set, but I've ordered a plate bumper and I'll be removing my stock bumper soon. Definitely a good idea to market...
Good luck with those.
One more thing I forgot to mention - You have to be really careful with the ground terminal on the back of the fog light itself. It's a male prong, on which you slide the female connector from the rubber boot. The ground terminal bends easily, and I had to straighten mine back out a couple of times. I finally just pried open the female connector so it would slide on with little resistance, then clamped it back down with pliers.
Really appreciate your write up. I wanted to do this for long time and just couldn't find a good instruction. I'm ordering the parts for my 99 SR5 right now...
Well done man. I need to order a set off eBay sooner than later....I used to drive with them on all the time on my old 4Runner, because they really do help you see more stuff at night.
Do you have a local toyota dealer? Just go to the parts counter and order it from them. You'll have it tomorrow afternoon.
Agreed. I have ordered from Toyota Parts Zone a couple of times and it takes right at one week for it to arrive using regular UPS ground shipping. A local dealer may have it in stock, and if not should be able to get it in a day or two at no additional cost. This depends on where you live, but for me, Toyota Parts Zone charges shipping but no sales tax, whereas the dealer charges sales tax but no shipping. In the end there's not much difference. Good luck.
Just called my local dealers. They said they can get one by Friday. Hopefully I'll have all the parts I needed to start the project!
I bought the turn signal stalk from a local dealership. $99.10+tax. Just got the stalk installed and testing working! :banana:
I am still waiting for the Hella Fog light kit to be delivered tomorrow to complete the final step. So excited!:uzi:
So I ordered the fog lights linked in the first post to install on my 98, which has no fog lights. The kit now only comes with the lights and brackets, no relay, wires or switches, or even the screws for the brackets which is stupid. Anyways, I know next to nothing about wiring and lighting as it's just not something ive really ever worked with.
So I wanted to see if any of you guys could help me out with this. Is there a complete kit I can get somewhere that includes everything I need to get these things hooked up? What do you all reccommend?
cheers
cheers
you do realize the kit you ordered is only for 99-02 bumpers right? unless you have a 99-02 bumper these will not work.
did you even read the description for what you bought? not to be a ******* but did you even read that? because if you did you would realize that it is not stupid and that you screwed up. it was already stated in the ebay listing.
cheers
I ordered it from the same eBay seller last week. It says it includes everything you need like relays, screws and etc. While I'm waiting for it to be delivered today, I asked the seller if mine should have everything or not. Here is his reply:
"If your listing stated switch and such..then you got it..
i just changed the listing yesterday...you probably got one of the last bags that had that stuff in kit....thanks
- snappylights"
Wow buddy. Bad day? I sure did read the description and was aware of what I was getting. Thanks for keeping me in check though. I do think its stupid that they sell the bracket without the screws, especially considering that they used to sell them and just ran out a week ago. You would think they would simply order more and send them to me later as part of the set. But thats beside the point. My plan is to do a retrofit just like Blcktpgsr did. Check it out:
http://www.toyota-4runner.org/3rd-gen-t4rs/67705-blcktpgsrs-97-transformation.html
Notice that he and I have the same bumper. Amazing what creativity can do. I had just planned on getting a set of PIAAs and mounting them to my bull bar. But I kinda like the idea of fitting these onto my 98 bumper to make them look stock. Anyways, thanks for the helpful criticism. And have a wonderful day my friend
Philthyphilthy
