Installed Hella MicroDE fogs w/ new turn signal stalk
Nashvegas what type of barb did u use? Do u have a pic? I saw the one SKIDMRK did but wasnt to clear one how it worked.
See below. Basically I just routed the tubing through some holes in the bumper supports, taking it to about the middle of the bottom lip of the bumper. I zip-tied it in a couple of places to keep it secure. Really anywhere away from right in front of the tire would work.
I finally got the fog lamps and turn signal stalk installed yesterday. Everything worked great! The only question I had was the fog lights only comes on with the low beam. I turned off the low beam and the fogs went off with it even the fog switch kept on. Is it the way it supposed to work? How can I turn on the fog lights independently?
Here you go this should answer all your questions regarding the fog light operation and how to mod them to run off of 12 volt contstant
Toyota 4Runner Highlander Electrical Modifications Fog Light Mod
Pics or it didn't happen! At least one of the final result.
Thx man, exactly what i was looking for! Will post pics once i get the parts and get them done. Waiting on UPS...
Some pics show before and after my fog light installation. Hope it helps.
Does anyone know what style of the plug comes with the harness. I want to install HID's but dont want to cut the harness from this kit, I would rather buy an extra harness and solder that to the HID's
hi all......bumping from the dead....
im terribel at wiring plain and simple, but i just purchased some used OEM fog lights for what i think what was a good deal. now i am attempting to install these in my 99 sr5. what can i do to make this as simple as possible to install?
i like the idea of the stalk for a more simple operation.. im hoping this is already is plug and play cause i do so those pigtails dangling behind my bumper...
help...
help...
You have to
1) Install a turn signal stalk that has the fog light switch on it. I bought mine from Camelback Toyota. The installation is very easy.
2) You need the fog light relay to put in the fuse box under the hood.
3) Install the fog lights and plug them into the plug that is currently dangling freely, and is wrapped in with the front turn signal lights.
Then they should work.
You have to
Is it possible to install after market lights using the free fog light harness, and not use a stalk with the fog light switch? In other words, can the fog lights be made to turn on with the headlights using:
1) factory fog light harness
2) fog light relay
3) Sr5 non fog light stalk
2) fog light relay
In a word, yes. You'll need to find the black wire with the red stripe coming into the cab near the drive's side kick panel. This wire would normally lead up to the switch on the stalk, but would need to be cut to lead your new switch. Then connect the other side of your switch to the green wire with black stripe that comes back down front the stalk. This would bypass the switch in this diagram (c13).
