Jeeeeez how big are the spacers !?![]()
Dang, she looks mean. How big of a pain are the cam tabs to remove to install the Taco Tabs?
Sent from my SM-G986U using Tapatalk
Never mind I see now. I thought they were like the TC ones where they are replacements.You keep the cam tabs in place to mount the Taco Tabs, you shouldn't remove them. I can grab a picture tomorrow.
If you mean removing the bolts and cams I did that a couple years ago and had to cut out at least one due to seizing and my truck really doesn't have any rust. It was super easy to remove everything this time.
There was a guy that had some ray 10's with a conversion and holy sexy hellYet another dilemma: trying to decide between
Beadlocks
OMF beadlock conversion on my SCS wheels
Method Trail Series 701 bronze which is similar to a beadlock but without the hassle
I doubt my SCS wheels would fetch much on the used market due to how scratched they are, making the OMF conversion about the same cost to me as buying true beadlocks.
I'm just not sure if I need much capability past 10-12 psi of what the Methods can probably do. But the OMFs look so nice.
If you can its a great time to buy
I've not heard of the resistor mod. I know the Sylvanias I have won't last forever. They take some abuse.
Your oil temp sensor plan reminds me of a question I wanted to ask. I have read the 2UZ typically runs low pressure, or is this BS? I was wondering about an oil cooler, but would the extra capacity and distance traveling to the cooler be a hindrance for an already low pressure system? I've got a good guage here at the house, but am reluctant to install it and find out how low it actually is lol. I've heard some have seen as low as 3-5 psi at idle.
Beadlocks
I’m at the same spot with my new build, can’t decide between the 700 series methods or a set of KMC Machetes. Leaning towards the KMCs in machined finish for all the bling.
I probably won't regret getting the OMF conversion, I just don't know if I will wheel below 12psi. Beadlocks look so cool.
Yeah probably a little overkill for me at this point, but why not. I have 37 x 13.5's on stock wheels right now so airing down at all is sketchy. Might as well go with something that I can air down as far as I want.
Made some modifications to the JBL emblem, changed it to say JL :biggrin:
