JBA UCA owners: What's your wheel/tire setup?
might be able too. it's so close that you might get lucky, or the alignment plays a role in it. also probably depends on the tires.
255/80/17's on 6 star 5th gen wheels. I'd prefer JBA over the SPC, but the possibility of rubbing is preventing me from pulling the trigger. From the looks of it I should be able to clearance what I need with a grinder. But, I'd prefer to do it before I install them so I can repaint the raw metal prior to install, otherwise I'd have to install them twice. Once for test fitting, and again after paint/powdercoat, which is my biggest concern.
I should have done my homework better. I just swapped out the eBay suicide uniballs for JBAs. I have 285/70r17 Duratracs on Sport wheels with 1.25" Spidertrax and get some rubbing at near-full lock.
If I swapped these Sport wheels out for something else down the road, likely the TRD Pro wheels or just TRD OR package wheels, would that resolve it? I'd love to ditch the spacers entirely but that means I'd have to get a wheel with enough backspacing to compensate for 1.5" spacers and then some?
I think the Duratracs rub simply because of the aggressive sidewall tread.
Anyone running JBAs with Icon wheels or at least 17x8.5, 0 offset and 4.75 bs? Will I run into rubbing issues? Have 285/70/17 and planning on getting Toytecs Ultimate lift. Any advice on what UCAs are best for this setup..
I plan on running SPCs when I lift. I will be using 5th gen trail wheels and cooper 285/70s. I have heard far fewer issues about rubbing with SPCs. Plus I think red looks kind of tacky, especially against my silver paint. Overall I think it's a pretty clear choice for myself, but maybe I am just misinformed and haven't done enough research one both of these brands UCAs and their respective fitment.
Running JBAs with a 3" lift (Bilstein 5100s, Tacoma and Toytec springs) with FN FX Pro Wheels (17"X8", 0 offset, 4.5" BS) on 285/70/17 KO2s. I am not running any wheel spacers. I have no rubbing on the upper control arms whatsoever.
Well, I think I'm ready to just bite the bullet on new tires/wheels for a number of reasons, but rubbing on the JBA UCAs is one of them. Currently have 285/70r17 Duratracs on 17" Sport wheels w/ 1.25" spidertrax spacers, and the rubbing is very much because of the sidewall tread on the Duratracs and the crappy offset of the factory wheels.
A buddy helped me take a few mm's of material off the UCAs where they are rubbing but they still rub. We're thinking we'll have to take a divot out instead of a clean line to have the tire clear. I've been wanting to ditch the spacers because I'm sick of taking them off every time I need to work on common things and then being OCD about torquing them (or god forbid a shop takes them off and then I have to go back and check their work after). These tires are at about 12-13/32's, so I'm seriously considering just being done with it and getting new wheels/tires.
That handy chart above lists
LT285/70R17 (32.7" x 11.2") tire on 17 x 9 wheel, -12mm offset (4.50" backspace)
LT285/70R17 (32.7" x 11.2") tire on 17 x 8.5 wheel, -9mm offset (4.30" backspace)
There's a set of XD wheels that aren't god awful and have -6mm offset and 4.51" bs. Would that clear? I'm also super interested in the FN (f)x pro's but I think they are only 0 offset and 4.5" bs? I forget how offset numbers work...
What is the width of the rims you are deciding on?? That will come into play also!
So that's an inch or more over my current 1.25" spidertrax and Sport wheels?
Stock wheels are ET30 (-30mm), -6mm nets you 24mm and 0 offset is 30 mm from stock. I would go with the 8 inch width to make sure, you are now adding an 1/2 inch (-12mm) back to stock. I have 1.5" Trail gear spacers with stock wheels and 255's and have a good inch clearance. I have switched (working on it) to FJ steelies to get another 15mm, going to switch to 275's soon.
I am running JBA's and a 3" Dobinsons setup with 275/70-18 (approx 33.5x11) Duratracs on some Dick Cepek wheels that are 18x9" with -13mm offset. I have no contact between the tires and the UCA's and my caster is ~4 degrees.
I know on TW there were some guys that put 285's on stock wheels and rubbed (no sh*t right?) I think if you keep the tire width reasonable and run a wheel that has a better offset than stock you won't run into any issues.
Hey marlin, deeznutz told me to call you....
Anyone running 5th gen Trail wheels (+15 offset) and 285/70R17s with these? Will I need spacers?
Edit: Marlin said it won't clear by a measly .425" - guess I'll need Spidertrax if I go this route...hope they don't stick out too far.
How wide are those rims? I have 18" limited wheels from 07 and I think they're 25mm offset at 7.5" wide. I get rub at full lock with 255's but spacers make the tires rub on the mudflap so I took them off. Now I'm looking for some 17" Sequoia wheels which are +12mm offset on 7" wide. I think this will give me about .5" of clearance.
17x7.5 +15, it would add .39” for you. Might work if it clears the UCA. I’m pretty much guaranteed to take off the mudflaps and push the fender liner in and trim some bumper at this point....+15 offset + 1.25” spacers.
JBA installed:
Patagonia MT 35x12.5x18
Monster Edition Eb9 wheels 0 offset
Spyder trax Spacers
sa-overland-albums-sa-overland-build-picture59930-130463075-10208603351478124-9068886698631839100-o.jpg
erinobr2000
