Key - keyhole (ignition) locks up - won't turn
When the key is out, the steering wheel locks.
Lets say you are turning into a parking spot and then turn off the vehicle. The load on the tires (steering rotational load) will cause the steering wheel to spin back and lock under pressure. To get the key to turn you may need to muscle the steering wheel back toward the direction of your last turn. This will allow the key to release the lock. (this has happened to me)
OR if it is just gunked up. Spray some WD-40 into the lock. This will lube the lock and flush out the gunk. ( place a rag on the floor to catch the WD-40 and gunk)
So I'm not clear if the problem is the ignition needs replaced or the shifter lock needs to be adjusted. What would be the best steps to get the key stuck in the ignition fixed.
Dave
Mine does this too. But I pull out the key, spin it 180 degrees and put it back in. Seems to work every time after that.
DM
Same here, plus keeping the wheels straight when parking helps. Pulling a little on the wheel when it's locked up can help.
I belive the problem is a worn ignition.
This exact same problem is happening with my 4runner. I'm going to try the lock smith first to replace the tumblers. Anyone have any bad luck going this route?
I solved my issue by going to the dealer and getting a new set of keys cut from the VIN. Just take proof of ownership with you.
At work we have the biggest lock shop in town, my guys tell me its almost always the cylinder, bonus, they're usually simple to remove and a competent locksmith should take about ten minutes to replace tumblers
After much research...
Ignitions are generally made with the wafer tumbler system and Toyota decided to get EXTRA complex and devise a split wafer system. (single on the left, split on the right in photo). So I don't know if the worn-down key is the chicken or the egg, but the split wafers get worn and dont respond accurately and slide into position so that the tumbler can turn, causing the jam we fall prey to.
If I can find a good locksmith I will find out if just the wafers or the keys as well need to be replaced...It sounds like both would make the most sense
i driver my runner everyday and i have the same problem, some times im trying to get it to turn and takes up to 5 mins til i can actually get my runner to start........
Just some more info on this matter.
I pulled my ignition cylinder and brought it to my local locksmith. They repaired the ignition cylinder for $20 and even made me a new key. A lot cheaper than replacing with a new cylinder and having to get re-keyed. Just thought I'd pass along!
Untitled by MikhailCaz, on Flickr
This is a great post.:nod:
I'm sticking my key in, turning my steering wheel and after a try or two, getting the ignition key to turn to ACC and then starting my rig.
So that is apparently the lock cylinder or tumblers?
Not the ignition switch?
purchase new lock cylinders
Hello all:
I have had similar issues as to those previously described. My spare key, the main key I use, is slightly bent and after years of use have made the ignition and driver's door lock difficult to use. If I use the original key it works, but with the same degree of difficulty. The spare key no longer works in the glove box because it is bent. On a side note, my back window lock was punched out by someone and has needed replaced for a couple years.
This said, I am looking to order and replace the entire set. I looked at prices and found competitive prices at Toyotapartsoverstock.com.
My main question is with the part number. I see two listings for the cylinder lock set, both 69503. However the prices are different, $333 and $293 respectively. I see nothing different aside from the sublisting of assemblies. The first set lists RZN18# and VZN18#. The second set listing shows the previously mentioned two also it show SR5B, SR5V.
Can someone explain to me the difference between the two lock sets? I want to ensure I order the correct set.
Appreciate it.
Enjoy your day,
Kyle
I have a question about this same issue. I just purchased a 2000 Limited and it starts fine but if I take the key out and then put it back in the ignition and try to start, its hope and pray and jiggle, jiggle and shake and hope it turns over. When I looked it up on Toyotaoverstockparts, they list a cylinder W/O tilt wheel, but mine has a tilt wheel. So, I'm not sure what part number to order. Thanks in advance for any advice. Looks like I will be spending a lot of time on this forum.
Glad to see there is a somewhat simple repair. So annoying to have this happen in public. The only thing that worked for me was to insert, try turning and remove the key multiple times until it worked.
I have had this issue in every vehicle I have owned. Its the pressure on the lock, but after time I guess I could see it wearing out, but a little jiggle, take the weight off the lock by moving the steering and always started up.
I had a kid in a 2012 Kia come by delivering pizza, noticed he wasnt leaving and get out and get on his cell phone. I went out and asked wuts up he said he was calling a tow truck, that his ignition always locks up. I asked him if I could try which he was very hesitant to do and I jumped in, moved the steering, started her up and the guy was freaking out. Said the dealer couldnt even figure it out. It was pretty funny.
I've had the issue for a while. Got stuck for a few minutes several times. Best solution aside from actually fixing the problem was to go to Home Depot and get powdered graphite for locks. Not wd-40!! After you put the graphite in take the key and "fck" your ignition for a little. Consider it for play for getting her motor goin :wink2: and eventually the graphite doesn't do its job as well so just add a little more. Really just think of it like sex. Oh hey that's gettin a littler dry huh? Lets add a little more lube and keep goin!
For what it's worth, you don't want to use WD-40 or graphite. Yes, they both will work temporarily and get you going but in time you are just making things worse. Toyota, for just a few years experimented with split-wafers, meaning instead of having one wafer per slot they would divided it, they normally only did it to like the 2-5-7 slot I think. This was there attempt to keep people from picking locks because, well you just can't pick a split wafer lock. Only problem being that, it meant these locks over time would get dust, lint etc.. In the slots and cause the split wafers to jam. Your best bet would be to use something called tri-flo which is a dry lube not wet like wd-40. Just like a chain on a bicycle, if you use we-40 and go for a ride you notice the chain is dirty from all the dust collecting on the wet lube, so instead you use tri-flo or white lightning and your good to go. Second, dry graphite is no good because basically your putting contamination into your cylinder, and being most manufacturers use a grease to lube the cylinder that graphite will just clog and make springs not want to work very good. Take it for what it's worth, but if you have a TR-47 key and have not experienced the cylinder locking up on you then I guarantee eventually it will, best fix is to remove the cylinder and remove the split wafers, just leave the slot blank and you will never have a problem again.
Hey Guys,
Thanks for the replies. I know a lot more now than I did when I came here. But, to fix this problem once and for all, do I need to order part #69503 at $293, or is the only other option to take the cylinder out and take to a locksmith? Or should I take my VIN# to Toyota and have a new key cut first? Thanks. Sorry for being so ignition illiterate...
I'm gonna try this route.
I just replaced my ignition cylinder and now my Runner won't start and the doors won't lock. I have the old cylinder out and I am going to get a key made from my vin and then get the cylinder checked by a locksmith with the newly cut key.
did you ever resolve this?
Hrt4me,
Yes I ended resolving it to the tune of $565, mine was so bad that the cylinder had to be completely rebuilt, a new key cut and recoded. I tried the locksmith route but they couldn't figure it out, so I dropped my pants, bent over and let the stealer has his way with me. I feel so used!
charlesz
