lets see them CB Antenna Mounts
bumping this. I am still looking for a few options.
Thinking of just getting a diamond k400 pinch mount but much prefer a bolt on version.
The rigo version requires drilling into the bumper which seems pretty weak and afraid it will break off if i hit branches
I went with the CBI ditch brackets. I used the right side one for my firestick on a spring mount. I have an extra left mount if you want to go that route...
I use the Diamond K550 mounted to the expanded metal floor of the roof rack. It stays down most of the time but when I'm road tripping or want to use it, it goes up in literally 5 seconds. I have easily 7 mile clear reception while doing 75 down the freeway. I have a 5' Firestick and on spring in case I forget and go through a drive through. Lol.
How did you run your coax wire? I have a gobi rack on my 4th gen and want to do this but unsure where to run the wire through. I'm trying to decide between this or CBI mount.
Yes, but you must widen the hole. Here are are some pictures of my HAM antenna.
How it looks on the Runner, from a distance.
Nice, thanks. What is that type of mount called? Is that the same as what would be used for a roof mount? I've only ever used a magnet mount so not familiar with the different types of mounts available.
Diamond knockoff from Amazon. Can't remember how I found it or if they still make it.
Actually, I meant what the antenna is screwed onto with the cable.
I had a ham antenna on the CBI ditch bracket on my '15 Trail. I do not remember the model number but it had a 3/8" stud that went through the bracket and did not require the 3/4" hole NMO mounts normally require so no drilling of the bracket. I seem to recall that Larsen makes one of these but mine was a Telco, Teledyne or something along that type of name.
I just did a search on Google for < 3/8 inch NMO mount > and there were several. Mine was from PCTel. The top section is like a normal NMO mount so many ham antennas will work with it.
Rago Fabrications has a new CB antenna mount option. Looks nice and mounts just beneath the rear driver side tail lights.
Both are diamond K400 mounts. CB is a 3ft tuned Firestik, and the other is a Diamond dual band antenna for HAM.
Diamond k400 + 2ft firestik + fire ring
So I'm new to the forums and am still figuring out how to use all the features the site has to offer, so my apologies if it's already been answered... but what rear bumper is this? I absolutely love it!
