dktxt4r
looks greatany pictures of the full side of the truck?
Driver's side view.
Driver's side view.
wow that looks great. i'll probably do the same until i get some sr5/trail/pro rockers. those things are like $180 each + shipping.
looks like you did the pro front bumper, did you do the rear too? also what size tires do you have? any lift?
i also plan to do the same to a blizzard pearl as well :happy:
Which bracket are you referring to? There's a plastic piece that runs along the bottom side of the head lamps that don't need to be swapped out. The one's at the bottom front of the head lamps need to be swapped. See photo below circled in red.
There was a forum member selling his trail front bumper because he purchased a full steel aftermarket front end. He gave me all the parts I needed for the front bumper swap. I took it to a local shop to paint and it cost me $480. If you can find a front end with the same paint color, you'll end up saving a lot of money.
I also plastidipped the lower valence in black. I have a C4 fab low pro bumper on order so it will be going on when it arrives.
*EDIT additional info
You're also going to need to swap out several other pieces in the front bumper to do the conversion. You can reference [MENTION=126538]2nd Chance[/MENTION] thread for everything you're going to need for the conversion. His build thread gave me the info and confidence to do this myself.
can you confirm the brackets under the lights which need to be swapped are
52134-35070 RETAINING BRKT, LEFT
52133-35060 RETAINING BRKT, RIGHT
thanks
It should be 52133-35070 retaining bracket left and 52133-35060 for retaining bracket right.
the bracket for the right seems correct. oddly, the bracket 52133-35070 on the left does not exist. perhaps you have a typo? i've added the links for comparison.
when i look it up .. these are what i find
Must be a typo then. Sorry about that. That was the part number that was given to me. Fortunately for me, I didn't have to purchase it since it was included when I bought the front bumper.
I should clarify. It does not have the Limited Rocker trim, it has the trail rocker trim.
75805-35130
75806-35100
75857-35010
75858-35010
Cost $436.45 shipped.
It wouldn't look terrible naked, but it's best to keep that part of the vehicle as protected as possible.
Yea... I wanted to keep it the same size. I couldn't decide on tires so I just went with the stock setup of Terra Grapplers. Was really torn between the KO2 and General ATX. No one local sold the Faulken or I probably would have gone with those.
My wife jokes I'm trying to make a TRD Pro Nightshade Limited.
I keep the original 20" rims for doing long highway trips. They're a little quieter.
Where did you buy the parts?
Completed the Limited rocker panel mod. Used a dremel to cut the panel and used a car door edge guard trim to clean up the look. I initially wanted to buy the trail edition rockers but they were too costly for me. Shrockworks TE trim was an option but I ultimately decided against it.
Preparing to install some RSG sliders. Anyone have any tips regarding the X-REAS lines for the slider install? Is is pretty simple to unbolt, move out of the way, and install on top of the slider plates?
Has anyone installed the 2019 LED trd pro oem fog lights on the limited yet? It says that the install is different for the limited and wanted to know what that entails..
I don't know if you have done this yet but I completed this just this weekend.
https://www.toyota-4runner.org/5th-...imited-fog-light-replacement.html#post3294515
Wow! That seems like a lot of work! I wished I had known this before I ordered the fog lights. I thought it was going to be just screwing the existing one from the back. How long did it take you to do this?
So then I had to trim the rocker panel, re-install, and find creative ways to tie the X-REAS system to prevent movement. I used a velcro strap with grommet and zip ties to create counter pressure on the system and to prevent the lines from rubbing on the gussets of the slider plate and arms. I'm still unsure if this is going to be secure enough. Anyone have any suggestions on how best to secure the X-REAS?
