Limited Edition Mod Thread
planning to replace my liftgate garnish panel (door handle chrome) to black one like the nightshade edition, somebody knows what the part no. for the handle please?! looking for similar on the photo here
I would like to do this for my limited as well. I’m assuming the night shade version has the Toyota emblem and letters already painted black ? For now I did the plastic dip and seems to be holding up well.
I did something a little different to standout from all the rest. Color matched the chrome to BP and then used black overlays.
FYI I hear that panel is a PIA to remove.
I just put on new SCS SR8's (-10mm) and falken a/t3w 265/70/17 stock height. I love the look with this offset, makes them stick out just enough. However, i did have significant rubbing both directions forward and reverse on fender liner and mudflap tab, for anyone looking to do the same.
Got Daystar 2.5in leveling kit a week later, and still had the rubbing both ways, but only on the mudflap plastic tab (Tried to explain the caster I wanted to the alignment guy, but he just wasn't getting it). Removed the front mudflaps, and she rides and sits perfectly now.
Now the good part. Here's some comparison pics.
(Can someone give me the easiest way to resize images for this? I assume that's why it's not working. Then I will post them. Thanks)
Which part numbers do we need for the rocker switch?
rocker panels?
75857-35010 Rocker Molding Front RIGHT 1
75858-35010 Rocker Molding Front LEFT 1
75395-04010 Rocker Molding Fastener LEFT 2
75395-04010 Rocker Molding Fastener RIGHT 2
75805-35130 Rocker Moulding RIGHT 1
75806-35100 Rocker Moulding LEFT 1
76924-13020 Rocker Molding Retainer 16
90189-06006 Rocker Molding Grommet 2
rocker panels?
You're so helpful thank you
You could go the route I took, body color matched the chrome and did overlays on the letters.
Did you have a body shop do the color matching, or found a cheaper route? I debadged it and took all the letters off but would love to find a way to color match it without a body shop charging a few hundred to do it.
I did it myself with spray can factory color. Base coat, pearl coat and clear coat (3 cans). Not perfect but only I notice it. I put tape over buttons then cut out with razor blade. Used the stick on black overlays.
Thanks to all the inspiration in this thread I went ahead with a 3/2 Dobinson with UCA setup on my MGM. Looks better than I even expected - I think I even like it better than the Pros I’ve been jealous of in the past
b834ea54679ff8cf007da234d4dfab9c.plist
erinobr2000
