Long-Term Build
Sean , I have some good used A/C idlers for a little less , if your in need ...
also , I have been in "talks" with KTT for a Canadian distributorship .. maybe I can help you there as well
Thanks, Corey. I'll be up there mid July and will call you beforehand
Had some minor carnage on the weekend. I was on a trail cleanup, organized by 4WDABC.ca
Four Wheel Drive Association of BC - 11th Annual West Stave Lake Cleanup of Burma and Florence Lake FSR's, June 1st, 2013
Took off down a trail and forgot to remove my mud flaps. Oops... Ended up trying to back over something and tore them both off. One pulled through the bolts and the other ripped the mount off the frame. Luckily, I tacked them on lightly since I knew I'd forget them eventually. :)
Note to self...
On the bright side, we had lots of people turn out and we pulled over 25 tons of crap out of the roads and trails. :thumb:
Note to self...
Sounds familiar--I put some large flaps on my last truck, and after only a couple runs, they were both torn off! Oh well, I tried to keep those following me clean (LOL).
I haven’t been on here in ages but the truck is still going. No real changes and haven’t been using it much but it still gets out and turns some heads occasionally. :)
tuṣṭāva
