Nelsonmd's Build Thread
Looks great, and I thought the choice of the black color instead of the color keyed theme for the chrome surround was nice.:hatsoff:
Thanks, it should look better once I paint the little pieces black as well (I should probably clear coat it as well). I am toying with some ideas for changing the front bumper. It looks great, but gives crap approach angles. I found that out on the snow piles this winter (and spinning out on the highway and practically jumping the guardrail/snowbank). It is fairly broken already; if I change it, the new one will probably be black, so it will match up a bit better.
All the more reason to go the plate bumper route, right? hey I'm not one to oppose!
Haha! Yeah, I actually have had my eye on the addicted off road bumper or the badlands bumper if I were to ever go that route (they appear very similar). Right now I have had to say no to myself because I have never actually off-roaded (at least intentionally) so I can't justify the money right now. Maybe some day it will be justified.
My 2 cents....so take it for whatever it's worth:
I would paint the grill to match the truck, and the lower bumper filler plates (pieces below your headlights) are easily removed and painted. I did mine a couple of years ago...they were pitted pretty bad from road debris.
Other than that: THE GRILL LOOKS GREAT MAN! :guitar2:
Minor Update: I painted the 2 small pieces, and also clear coated both small pieces and the grill. It definitely looks better. Not as good as if it were color matched, but not enough to make me buy color matched paint any time soon.
IMG_3412.jpg~original
I agree with you that color match would look better, but looking at automotive touch-up, it would be about $50 for primer, paint, and clear coat, and hope it matches exactly. This way I spent $10 and am not worried about it matching. I may do that some day, but I am hoping that someone will post about a well matching IJM paint that I can use. I got a little touch up pen/brush, but I found it doesn't match well after drying, so I am a little hesitant about color matching.
Update 2: I have successfully done the "Rear window auto-up mod", but havn't put the door back together yet because I want to play with the trigger a little bit to get the exact behavior I want.
Right now, if I push the window down button on the remote 2x in 5 seconds, the window rolls up automatically. I am going to change this to pushing it only 1x, same as for rolling down, but it will only roll up when the window is all the way down, which means I will have to add a limit switch. I will take pics and do a write-up once I get it finalized.
I also plan on doing the same thing to my sunroof. I want to disable the safety stop at 100mm and make it a single press auto close. This will be a major luxury this summer.
hey Nelson
Hey,
nice truck. I remember when I had only 115k...
The Satoshi mod looks good. Was it as much of a PIA for you as it was for me?
:zoom:
Hey,
:zoom:
No, it wasn't bad. I did it while watching a Bourne marathon. Undoing the grill clip is annoying and I need to buy more after breaking a bunch of them, but not bad.
Wow Nelson, I just saw you installed the lift. How is the Ironman part of that lift riding?
That ironman stuff feels great, feels very smooth, takes the bumps very nicely. Havn't been off roading with them, but I like them so far.
Grille looks real nice, now you just need to paint the little trim piece on the scoop black! :artist2:
Also really interested in the back window mod, sounds cool.
Hey man,
The black bumper filler plates don't look too bad black....but I still think color match would be the best.
As for paint, just an FYI: I bought some paint from the Auto Parts store that is a very close match to the factory color...it's made by Duplicolor. You should be able to find your color there, and just give it a go! I painted my filler plates, rocker panels, and inner door jams using this paint, and it works well. The paint cost me about $10.00 a can, I bought some Filler Primer for around $6.00, and some Clear coat for around the same amount as the primer. So all in all, about $22.00 bucks! If you look at my build thread, you'll see the bumper filler plates on mine, they are starting to show some wear again, as I do alot of highway driving...so might paint them again this summer!
Oh and BTW, that rear window mod sounds pretty cool! You'll have to try to post a video or something!
Cheers for beers man!
Oh, I forgot one other little update...
I pulled the parking brakes off a while back, cleaned them up and painted them, then reassembled them practically filling the boots with silicone grease. They look good now and shouldn't rust for a long time.
I also properly adjusted the rear drums, and wow, they were way out of adjustment. The brake pedal is now very stiff and the 'ole girl doesn't nosedive as much when I hit the brakes. The parking brake also has a very good grip now. I was able to hold the car halfway down my ramps and in gear with just the parking brake.
Here's the pic of the new color scheme.
IMG_3416.jpg~original
The shininess is the fluid film I sprayed on everything once it was assembled. You can also see the gear oil spray marks on my tire from the leaky axle seal. No new streaks now, so hopefully I seated that seal correctly.
IMG_3414.jpg~original
Here's the other side. There are a couple spots of surface rust on my new axle and panhard from where some of the cable mounts broke off and banged against the axle, scraping the factory coating off. I will be wirebrushing those areas and POR-15ing them this spring.
Today I did the Auto-shut Sunroof mod. I have always hated that the sunroof button has to be held down to shut the sunroof, and even more annoyed that it stops half way and forces you to re-push it. Not any more! Now with 2 quick clicks of the button, my sunroof auto-closes.
Sorry the file is so big. By the time I realized it was big, it was too dark to take a smaller one.
Anyway, Here is the write-up for this mod, which is really 2 mods in one.
First, the simple mod, eliminating that annoying half-way stop. This one is super simple. Take the unit off the roof, and coming from the Moonroof control relay and switch (white thing in the below picture, there should be 6 wires (there are 2 versions of this control, this is for the newer version, I think '99+, though the previous years should be similar).
CicuitCoverandSwitchdisable.jpg~original
While I do have an FMU, this control relay came out of my original roof unit. So all you have to do is cut the wire to the limit switch, in my case, it was the yellow wire coming out of the control relay. I found the right wire by looking at the connector that plugs into the motor itself, which had 5 wires whose colors matched the FSM schematic shown here
Schematic.jpg~original
I found the red wire, followed it to the Control relay end, and snipped it there because I had more room to patch it later should the need arise. EDIT: You should ground the side of the wire that connects to the control unit; this will prevent hesitation of the window when opening (described below).
Clip that wire, and you are done. You now just have to hold the button down, and it will go all the way in. You will hear it click as it passes the 100mm point, but it keeps going and automatically stops at the end just like normal.
Now, onto the auto-close mechanism. I borrowed the basics from a guy in the 4th gen section that did a good write-up, so instead of bogarting his work, I'll link to it and skip that part of the write-up. He does it for the rear window, but the principal is the same for the sunroof.
http://www.toyota-4runner.org/4th-gen-t4rs/85203-back-window-up-hack-factory-key-fob.html
So where I departed from that is that I didn't add a limit switch, so I can trigger the auto close anytime. I used a PAC TR7 and a 12V 40A relay just like he did, and spliced the trigger wire into the motor power wire (pin 2/4, light blue above, light blue because that is the high side when closing). The big difference is in the relay bypass wire. If you open up the control relay and look at the board, you find that the open and close buttons are just normally open switches that close to ground, so to keep all the stock functionality, I want the relay to act like this switch. Now that means bypassing the switch only and leaving the rest of the logic in tact. This is the tough part because it means soldering directly to the board. I found that the close-button switch connects to a via, then to R3 in the pic below.
BypassSolderJob.jpg~original
The red arrow shows the trace from the other side of the board.
The VIA is too small to solder a wire to, so the only option is to solder directly to the side of R3. This isn't the best way to do this, but there is enough joint there that it is doable. I was hoping this node would have a test point (in fact, the open switch does have a test point) because they are big enough to solder to, but alas, it didn't. The test point between R3 and R4 is on another node, I know because I tried. Solder the smallest wire you can possibly find (and preferably solid core wire) to this resistor as I did.
WARNING: I don't recommend trying this solder job unless you have a good soldering iron (not a $20 radio shack special, a real soldering station) and some soldering experience. It is really easy to ruin components by letting them get too hot, and unless you have a good iron and experience, you run a big risk of frying that resistor or creating a very poor solder joint that will fail later.
You then have to modify the control relay cover a little bit to allow the wire to exit. I just used a knife and cut a small notch that worked fine.
CircuitCoverMod.jpg~original
Run the wire out, and connect it to the high side terminal on the relay, and you are done. You can tuck the relay and TR7 up in the roof on the pass side, then shove the giant rat's nest of wires in there and reattach your roof unit.
That's it. I noticed that after all this, when I hit the open button, it flinches, then stops, and I have to hit it again to get the sunroof to open. I suspect this is due to clipping the wire for the limit switch, but I am not sure exactly why it does this. I am going to try tying the yellow wire I clipped to GND and see if it fixes it. I will do that another day as it is dark now.
I am still thinking about the triggers on the rear window auto-shut circuit, so I haven't finished that yet.
This is an awesome thread. I like that your truck is in similar (slightly better) than mine, but has a lot of the same problems, and that you are doing something about them. This is very educational for me.
Thanks. I see you are a bit farther north of me, so still in the rust belt. Yeah, By the time I am done, most parts on this things will be new. It is costing alot, but I am also learning alot, and that is big as I am now fixing my pastor's 96 limited. He has alot of the same problems, but not the money and time to fix them, so I am fixing them on the cheap using what I learned from mine.
Hi NelsonMD...I would like to do this mod to my 98'....how difficult is this?? The sunroof button really bugs me....it would be nice to hit the button and it would close...and do I need any special tools/supplies. Thanks very much!!!!!!
You tell me how difficult it is. It was easy for me, but I have experience soldering and electronics. It isn't very complicated and should be doable if you are a capable solderer and understand a bit about electronics.
Tools and supplies are just what is shown, a good soldering iron, some wire, maybe some zip ties, some heat shrink tubing would be good. Standard stuff. I used wire splices as well, they save alot of time and effort.
Your 98 may look a bit different than mine, but it should be the same process.
erinobr2000
