Like others I’m in the replacing mine tho I’m not as lucky as the rest of you who have changed.
The top bolt came out nice and easy the bottom nut came out nice and easy
Went to remove the sensor and it wouldn’t come off. Took a wire brush to get some of the gunk of it where those little compression wings are and on fell off then another. Last 1/4 wasn’t moving. Sprayed it with some pen oil and let it sit
Went back with a little pry took and well the sensor came off but the metal ring that you put the lock nut and washer on stay on the vehicle so I have the sensor off just need to figure out how to remove the metal attachment that fit on the box shaped piece stick out of the tranny
Any ideas? I’m thinking I may just use the dermal to cut it the metal to remove it
