What do you all think of this. I really don't want a big lift. Looks cool but I really drive on road. But hate stock tires. I'm going to upgrade and i also like the look of the red coils and leveling the truck out. I think you will be able to see the red coils through the fender gap. So i may get toyotec Front adjustable coil over kit with Bilstein 5100's. Looks so good. Run stock rear. And when and if i move to mtns i can raise the front and get rears. I also want to run a more aggressive tire like the MT/R in 275s because they won't rub. So stock rears... Front adjustable coil over kit with Bilstein 5100's and 275 MT/Rs.
Also don't like the way the truck squats so much under braking and acceleration. of course accelerating would prolly need the rears stiffer.
but i'm sure the coilovers would help.
here is pic.
i measured to the bottom of the fender... are we saying the same thing?
do you mean that the stance doesn't look raked to you? or that our measurements are close enough?
stock size 265/70/17 Goodyear Duratracs on mine...
i hear you re: spacers insofar as a true lift goes, but i consider this simply leveling it out front to back. if i were truly lifting it i'd go with new shocks and coils at all four corners.
if you're just leveling out the front the tires shouldn't look any smaller than the rear ones look presently, no?...
Yeah I think we are on the same page...
Do you or anyone else on the forum have any suspension mods with 265's. If so, id be pretty interested in a picture?
In other news the 5100's will be here Thursday and I am hoping for a weekend project pending nothing more pressing comes up. Ill be dialing them in for 1.5" and of course will document with pictures.
Keep your fingers crossed for me...
^^ 1/4" length shouldn't be that big a deal. When I installed the extended length Coilovers in my Tacoma, I just had my brother step on the front brake disk/hub portion and lower the lower control arm just enough for me to slide in the coilovers. Other's I have read will just pry the arm lower using a crow bar or something. Good luck with the install, post some pics when all finished.
Nathan
Anyone else notice a difference between the front left and front right factory coil springs? I installed the Toytec front spacers on my '10 Limited a couple days ago, and found the left front coil more tightly wound than the right front coil. The reason I immediately noticed the higher coil count on the left was because the spring compressor tool did not easily fit between the coils. Absolutely no problem on the right side. Left Front has 10 coils. Right Front has 8 coils. I did not notice this variance when I leveled my '08 Urban Runner. If memory serves, both of those were 8 coil springs. My first impression of the different springs is that one corner must be heavier than the other, thus requiring a different spring rate on each corner. Any other logical reason for this variance?
IMO I would go to 1.75"... At first it will look a little higher in front than the back but after about a week mine has settled down nicely
