Vegas
No answer from Eric either... So i spent a large chunk of today trying to decide between painless wiring aux fuse block and the blue sea set-up.... And since Antman was busy all day Armorall'ing his tires for the 8th time today, instead of answering my 500 PMs on teaching me about the history of electricity .... Not sure which setup is easier for my skill set... But Painless is in the name of one so?
I think I like the factory look of discretely putting the painless fuse block right next to the OEM one.... But with the blue sea fuse block there are several write-ups with lots of pictures of the install on are trucks which is a huge help to me.
Need to figure out if the painless wireless aux block can handle the future Mods I have planned so that I don't have to upgrade later on.
If not looks like the blue sea is the way to go.
So need to figure if painless will work for the about of AMPs or draw or volts whatever the correct term is with rigid lights,compressor, and back lighting my otrattw switches etc. also what gauge wire is needed and will the fuses in it work, or do I look on the accessory to figure out the recommend fuses need... And painless says it come with everything you need... And the instructions look like they pull power from a fuse tap instead of the direct battery... Not sure though might not be understanding. But I would rather pull from the battery and put a large fuse between the two.
Lots of homework
Lots of homework
