New Twist on Lower Ball Joint failure
Me thinks that the factory bolts are fine. How many sheared bolt failures are there, freak accidents/hits aside?
LBJ failure seems to be a hidden wear issue due to high mileage and not being a fail safe design. I wouldn't fret about the bolts.
This is making me wonder if the OEM bolts could be upgraded to a higher strength / class fastener. I need to verify but I think the factory bolts are metric class 8 which is equivalent to a grade 5 SAE. A stronger bolt like metric 10 or 12 would allow us to install the LBJ with higher torque values.
I can't see how it could hurt. Most failures are not due to correctly torque'd bolts though but the ball joint itself shearing off after all the grease leaks out.
aawolf- did you reuse the old bolts?
I made a thread a few years ago covering the LBJ bolts:http://www.toyota-4runner.org/3rd-gen-t4rs/221269-umm-did-i-receive-correct-lbj-bolts.html
Looking more carefully I think the factory bolts are class 11 which is quite strong. ARP chromoly studs and nuts might be the only real upgrade.
So after seeing this I legit purchased some lbj but I have some doubts . I posted in the what did you do to your 3rd gen today but figured I’d post it here as well since it makes more sense here.
I Got my ball joints in today from amazon but to my surprise amazon stickered over the Toyota part number? Wtf? How do I know if these are legit? There’s a Toyota sticker underneath the amazon sticker but anyone can resticker the bag. Plus I can’t read what the sticker says underneath because again the p/n is blocked off... any help would be appreciated are there any indicators I should look out for that let me know they’re legit?
ghengiskhan
