Now Available! Acrylic Fuse box platforms for 96-00 and 01-02 4runners!
Hey Jim,
If I remember right, you have the Redline Tuning hood struts on your 4Runner, is that correct?
If so, is there any interference between the RT struts and the fuse box/platform/related components as pictured in the first photo of post #1 in this thread?
Also, roughly how many miles / how much time do you have on the dirt since you installed the acrylic platform? I ask because you mentioned that the bends have a tendency to open up and will snap easily in the absence of heat. Do you have any concerns about the mounts cracking over time?
Hey Jim,
Hey Nick!
The 01-02 version is the only one I can confirm works with the hood struts. The strut fits down next to the fuse box along where the wires are. It barely touches those wires when the hood is fully closed.
Regarding that comment I made. It is a very small amount they can open up, and is similar to a spring settling. I have lots of off road trips on mine and it is still in the perfect position, that is with the support leg keep in mind. I have no concern about excess movement or cracking with the leg-less versions.
Brilliant :) Just checking, the $15 for the digital file is that an editable cad file? Only b asking as my truck has the 1KZ-TE 3.0ltr diesel engine. I will likely need to tweak your design.
Many thanks
James
Sent from my ONEPLUS A3003 using Tapatalk
Many thanks
James
That is sent as an illustrator file (.ai)
But, looking at the 1kz engine bay. you would need a lot of modification to the design. It would be a waste of money IMO. I would just start from scratch on your own.
Man, talk about timing!! Finalizing a dual battery setup this weekend and have been contemplating how to the mount the fuse box out of the way. Is it possible to get these with no holes drilled? I've got three circuit breakers that I need to mount (2 x 250A, 1 x 120A) and they are not the blue sea ones, so my guess is the holes won't line up.
I can do that, yes. But I cannot guarantee the breakers will fit properly and clear the hood.
Hey Nick!
Cool. I have a set of the RT struts on hand and haven't been able to install them due to the current location of my circuit breaker. I've been keeping an eye on this product as a possible solution. Considering the price point, it's a better alternative (for me) than spending hours making a platform out of metal.
Nice, this setup has worked very well for me so far.
Could you please explain why you need a breaker for big 3?
He links [MENTION=44220]BigFishAllDay[/MENTION] Big 3 Upgrade thread so I'm pretty sure that's what he used. The way Bigfish does the upgrade is by creating parallel circuits. Since the main starter to battery connection is still there the circuit breaker just protects the 4 awg that he used for his parallel circuit.
If you don't do parallel circuits and up size the OEM wires you can and should skip this. I didn't even bother to increase the positive wire size when I did mine. I just ran new larger grounds. I'm running the stock alt so there really is no need to up the positive side IMO.
Oooh. Oooooohhh... That's gorgeous. Now, what about shipping for us poor Canuckleheads? USPS is the best option for 90% of us.
My long awaited fuse box platforms are finally ready to go!
Below you will find all the information you need to choose the right one for you.
Please refer to the FAQ before posting any questions!
Due to the differences in engine bays between 1996-2000 and 2001-2002, there will be two main versions of the platforms, with many options for each!
Every platform is designed to work with all Blue Sea fuse blocks, you do not need to specify which block you plan to use.
You can use any Blue Sea fuse block you wish: 5025, 5026, 5028, 5029, 5030, 5031, 5033, and 5034. All of the ones pictured are using the 12-circuit w/negatives (5026).
Ordering + Options
Base price = $35
Each kit will come with:
-The unbent piece of acrylic
-All necessary installation hardware
-Installation Instructions
-Kits will NOT include any of the electrical hardware or the fasteners needed to attach them.
TO ORDER: Please send me a PM in the following format, see below for details on the options:
Option #1: Version A or B
A= 1996-2000
B= 2001-2002
The 96-00 version here with the optional spaces for a relay and 2 surface mount breakers.
Every part is located very specifically due to tight under-hood space, minor hood insulation trimming may still be needed.
View attachment 247873View attachment 247871
The 01-02 version is shown here in the optional fluorescent green with the optional relay, and 2 panel mount breakers.
The etched text is MUCH smaller on the production version you would recieve.
Option #2: Ignition relay (Yes/No)
Leave you room to add a relay?
A relay is basically an electronic switch that is activated by another circuit. The main circuit (fuse block) will then only be active when this other circuit is active. The most common method is to wire this relay to the vehicle ignition circuit so the fuse block is only active when the truck is on.
The relay meant for my design is this one:
E Support DC 12v 100amp SPST relay. $8.99 on Amazon as of this posting.
https://www.amazon.com/gp/product/B012N09BFE/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
For wiring help, see the below FAQ
Option #3: Number of Breakers (1 or 2)
Select two breakers if you also plan to do the BIG 3 Mod, otherwise select 1 breaker.
2 breakers on the 01-02 version is $5 extra due to it needing a support leg.
See below FAQ and wiring help to determine how many breakers you want.
Option #4: Panel mount or Surface mount breakers
Which Blue Sea 285-series breaker will you get?
Blue Sea 285-series breakers come in two styles, panel mount and surface mount.
*Please note that on 1996-2000 4Runners, surface mount breakers may require minor hood insulation trimming.
Option #5: Colors! (adds $10)
Standard platforms come in clear acrylic.
If you want a special color, that can be done for $10. Please allow 1-2 days extra lead time.
TO ORDER: Please send me a PM in the following format, see above for details on the options:
PM sent, thanks.
*EDIT- it has been claimed*
For anyone interested. I have an extra BY2P (01-02, yes, 2, panel mount) platform in fluorescent green, it has the larger text on it though. Production versions have much smaller text. Ill wave the special color fee and not charge the extra $5 for the 2 breakers on it for the first person to claim it.
$35 for a $50 platform.
These look fantastic. I took the inspiration for my platform from your old build, but mine isn't anywhere near as clean as these. If these were available then I'd have picked one up in a heartbeat. I may still swap mine out eventually for one of these. Nice work and thanks for making a nice affordable product for the community!
Thanks man! For what is worth, I probably wont be selling these very long. I only have access to laser cutters while normal school semesters are in session.
Philthyphilthy
