OEM Running Boards on 2014 4Runner SR5
My 2015 came with the slightly longer running boards but always preferred the slightly shorter with the lengthwise billeted holes running along the top. new ones cost about $350-$399 on Ebay. Like others have said, super easy, 6 sets of 2 bolts each, on and off.
PM Sent
Finally picked up and installed some boards (Toyota part# PT 92589140) from EB TOYOTA PARTS | toyotaparts.bochtoyotasouth.com
MUCH less than other dealers, like 1/2.
Was told this is the newest "OEM accessory" running board.
I wanted all black but these have a stainless, silver strip that I'm getting used to.
Install was typical which is fast and easy and stock mud flaps stay.
2015 Running boards question??? Help
Do these running boards seem a little low? Installed at the Dealer and they said it was the correct fit. Help anyone! Thank you for your help. Installed on our 2015 Model.
they are the correct running boards IF you have the limited, those are the R6 option code running boards.
that extra space to accommodate the rocker panels on the limited.
they should have ordered the correct ones for the SR5. those running boards don't fit the TE only the KH option codes fit the TE.
Sorry but yes, they are very low. They are decent boards, but my dealer tried to put those same ones on my truck. They told me they had a lot of these and were trying to get rid of them. They are after market "accessories" no where near what the factory puts on.........which in most cases you can't get.
Take a look at mine, I think the pix are just above yours. Mine are even lower than factory.
I purchased mine from: PT925-89140 | Toyota OEM Parts |*RUNNING BOARDS | Genuine Toyota*
They look all black, but actually have a silver stripe that runs the length.
Thank you!!
Thank you for that information! No we have the SR5 model and not the Limited. The dealer should have known which model number goes with our 4Runner. Now to call. Thanks again..
Personally I can't stand the look. The gap between the door and the step is not pleasing to the eye. Shouldn't they only install OEM parts and not aftermarket parts that apparently do not fit? Thanks
Bought the car 8/5/15 and had the dealer add the running boards. I was never told they would be aftermarket boards. (Discovered recently) I had called the dealer 1 week after install and they said the boards were normally low like my pics. Do I have a case in requesting them to swap out the boards for the correct ones? Hope so? Any thoughts??? Help. Thanks!
really depends on the dealer. unless you specified OEM running boards they can sub anything they want.
if your doing OEM
those look like the oem R6 running boards but installed incorrectly.
you can also fit the oem KH rigid running boards (they are the thin black ones that come on the trail editions only).
but since you said they are not OEM, aftermarket running boards are a fit all solution so they wont look right.
if your doing OEM
i have OEM running boards off my 2011 trail for sale, PM me if interested.
I have an 2015 SR5 and removed the running boards. They are the ones on the photo below. I also painted the chrome strip to black. PM me is you are interested or need more photos.
Dealer fixing problem
Got a call from the dealer and they finally admitted the running boards installed are incorrect. Having them swapped out tomorrow am. Thanks to everyone on this board who steered me in the right direction! Really appreciate your knowledge and time spent responding to my questions!!!!! Thanks again!! Post pictures when the job is complete!!
Finally have the correct running boards installed!
Dealer came through and apologized for installing the incorrect running boards. As my grandmother always said, 'The squeaky wheel always gets the oil!
Hi,
anyone in the los angeles or orange county area selling their "KH" trail running boards ? I need the pair for my 2014 SR5 . tired of lugging around a plastic step stool for my mother in law queen ;)
and how much are you charging and can you please post photo/s so i can be sure its the ones I like. Thanks so much !
is the silver strip on that running board ,painted silver ? or is that some sort of plastic or metal ? . im concerned about people banging their doors on that silver strip. Thanks
