Official Wheel Paint Thread
Painted mine dark bronze.
Where did you find bronze?
Really liking those Wrangler m/tr tires. May I ask how much they were. And I have stock wheels that came with my '97 base 2.7 liter 4wd 4runner. They are 265/70 R16. How am I able to tell whether or not I can run with larger tires? I think I might need spacers to fir anything bigger than what I have now. I see yours are 315/75 R16. Do you have spacers too?
I think they have discontinued those MT/R's. But, I could be wrong. I'm sure someone still has some stock of them...
Yeah I really liked them, I am surprised the phased them out...
Spacers? You mean lift spacers or wheel spacers? I had wheel adapters which are bolt on spacers. I believe they were 1". I did this to clear the upper a-arms.
And yes, I had a lot of lift to clear the 35's without rubbing. ;)
Discontinued?!
That is a shame, but I might get lucky and find a set.
Yes, I meant wheel spacers, not body spacers. However, How high are your body spacers anyway?
Should I get self-etching primer too before I cover my stock wheels with the color I want?
BajaRunner & prospectator - you guys have really nice taste. I especially like the wheels on BajaRunner.
Kopasz - not to hate but that Blue & Bronze looks so freaking terrible - just my opinion :whipping2
Self-etching
Can I buy a can or three of self-etching primer from an autoparts store? I did find some self-etching primer at Autozone today 20110803....august 3rd 2011.
How would I un-paint and re-paint my rims? I used some of that duplicolor graphite, and would rather have a OE looking silver finish. I would like to remove the graphite and get a different dupli-color rattle can.
sand? what grit, etc could take off the rattle can but not damage my rim? I did a pretty good job the first time, self etching primer and a couple coats of paint and clear.
You don't need to remove the paint that is on there in fact it will provide a good surface for the new paint to stick to. All you need to do is rough up the surface a little with a 3M pad (the redish purple one) and then paint them.
I would do 3 coats.
How did you do that two-tone? Just careful taping? That looks awesome.
Well with my baby boy crying, I didn't have time to tape. What I did was, sand the area that was getting paint. Then took some grease and did the area that wasn't getting painted. Wiped the rims down with acid tone and painted them. After they all dried, I wiped away the grease and cleaned the excess grease off with cleaner. Thanks a lot!
I would do 3 coats.
thanks man. should I prime again, or just go straight to paint? And saw you're in SD too...suhweet
Did you take the wheels off to do each one? Is that silver or white inside? What grit sand paper? What paint? How many coats? Thinking about doing mine the same way. Do you have a zoomed in pic of a wheel?
Also, anybody know if it's ok to paint brake calipers? I would like them red.
Did you take the wheels off to do each one? Yes, done each one off the runner. Is that silver or white inside? stock wheel color. What grit sand paper?I used 220 because, that's all I had. What paint? used auto paint by rustoleum, got it at wal mart in the auto section How many coats? 2 coats. Thinking about doing mine the same way. Do you have a zoomed in pic of a wheel? No I don't.
Also, anybody know if it's ok to paint brake calipers?Yes, they make brake caliper paint, at any auto parts store. I would like them red.
Answered all you question above in red. I just went in not thinking too much about it and turned out ok. :thumb3:
Clean before prime
What cleaner would anybody here use to clean your wheels prior to sanding/priming?
aluminum
Wheel cleaner for chrome. then after sanding, ready for paint, acid tone or lacquer thinner.
My stock wheels are aluminum alloy and are not chrome. Are you saying I should use Acid tone or lacquer thinner to prepare the wheel before primer?
I want to paint the wheels olive drab.
this is the official post pictures of your painted wheels thread.
I just painted my newly acquired 5 star wheels. I will post a full tutorial soon in a new thread.
there is a very good paint store called tcpglobal they are on the web and in san diego. look them up they are the ones to go see.
Post a link on here to your tutorial after you do it so we can find it.
I know they are but, you asked what to use to clean them first with. I'm saying to clean it before you sand them, use a chrome wheel cleaner, it's stronger. Then after sanding them, wipe it down with either one, to prep it for paint or primer. Has to have a oil/dirt free surface. Then you good to go..
Crookedcat
