Sure. I will try to post some pics tomorrow. I ordered same as what Jono has pictured above - dimple die front and rear, power coated.
Here are pics of my install. The LE slider has two legs vs. three I see on other models - I suspect because the third leg would mount where the XREAS center control absorber assembly is. Just loosened the XREAS system, slid the plate behind the XREAS lines and then secured the gusset around them as shown in the pictures. Hope this helps. Turns out they sent me twice as many brass/gold-colored bolts as required which initially contributed to my confusion. Used all the other hardware shown in the previous post's pictures once I learned where to use each of the lock washers and flat washers.
I don't know if this is the right place but Metal Tech is having a sale (til 8/31) for 20% off OPOR sliders.
http://www.toyota-4runner.org/metal-tech-4x4/145461-june-july-2013-sales-metal-tech-4x4.html
:happy:
:happy:
These look excellent. How much did they affect ground clearance? Do they hang much lower than other low points under the truck? Thanks in advance!
:happy:
How has the paint held up to the mass winters and 4 wheeling?
the order form says SR5, how do you let them know you have a limited and need the hardware for XREAS lines?
