Hi All,
I recently bought a 1999 SR5 to replace my aging 1995 SR5.
I am trying to swap my JVC deck into the 99, but it uses the "Premium Toyota Sound System" and I can't figure out how to hook it up.
I purchased the new proper wiring harness from Best Kits, and it links up, I get power, but I'm not getting any sound. One thought I had is that the factory wiring cluster is not matching up with the Harness. However, there is also another cable that has no plug to go into my new deck, which is the smaller of the 2. I know the larger one is the antenna, so I am assuming the smaller diameter plug is the Amp. The instruction guide mentions that this system may have a factory amp, and I may need another part to hook up to it called a "SVEN4" peripheral device. I noticed my JVC deck has 2 RCA line OUTs on the back, maybe these somehow connect to that smaller Amp cable?
Also, my best kits wiring harness has no negative speaker wires and uses a common ground wire, so I connected all the speaker negatives from my new deck to the common ground on the harness...I'm not sure if that's correct but it makes sense. From all the googling I couldn't figure this one out. maybe that is the problem.
Any help would be appreciated!
